Multi-volume database
In version 5, Progress V9.0, you have no choice. All V9 databases are multi-volume. You must either convert you V8 to multi-volume before you convert it to V9, or dump the schema and data from your V8 and load it into V9.
In V8 there are two reasons for going multi-volume: you are approaching the the single volume limit of 2Gb; or by moving volumes onto their own spindles, you may gain some performance by reducing disk contention.
"Dunn, Nancy" wrote:
> I am planning to move to Ver 5 in July. I would like to go to a Multi-volume
> database with version 5. Without getting into extreme detail, this is how I
> think I need to go.
> 1. Install Progress / Vantage ver 5 on server
> 2. Change .st file per instructions using the prostrct command (for ver 5)
> 3. Then "Upgrade the Existing 4.0 database" as per instructions of the ver 5
> install
> 4. Continue with ver. 5 instructions
> Will this work? Any thing I should know about a multi-volumn database?
> Thank you for your help
> Nancy Dunn
> Winco Ind. Inc.
> ndunn@...
> To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
think I need to go.
install
Nancy Dunn
Winco Ind. Inc.
ndunn@...
Nancy,
We just went multi-volume last night in Ver 4. I would think you would want
to go multi-volume in 4 before you upgrade but I would call Tech Support
with this question, they were super helpful last night. One fact the list
members should be aware of is if your Database is close to 2 gig in size you
must go multi-volume.
Sent: Tuesday, June 05, 2001 2:44 PM
To: Vantage Onelist (E-mail)
Subject: [Vantage] Multi-volume database
think I need to go.
install
Nancy Dunn
Winco Ind. Inc.
ndunn@...
Yahoo! Groups Sponsor
Yahoo! Website Services- Click Here!
<http://us.adserver.yahoo.com/l?M=201903.1443829.3021311.1268964/D=egroupmai
l/S=1700007183:N/A=662183/rand=339510891>
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
At what point does going multi-volume help? We are around 500MB on a dual 450mhz server with 512MB ram. 24 licenses.
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Wednesday, June 06, 2001 11:00 AM
Subject: RE: [Vantage] Multi-volume database
Nancy,
think I need to go.
install
Nancy Dunn
Winco Ind. Inc.
ndunn@...
