Multiple comparisons in BAM
Thank you...
I knew I wasn't doing it just right, but it worked, so I left it.
Aaron
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
netrippers
Sent: Monday, August 21, 2006 5:37 PM
Subject: [Vantage] Re: Multiple comparisons in BAM
Aaron
In the case stament use the DO: END.
CASE c:
WHEN 0 THEN
Return "Cancel Send":U.
WHEN 1 THEN DO:
This stament.
That stament.
END.
WHEN 2 OR WHEN 5 THEN DO:
END.
OTHERWISE...
END CASE.
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> Rich,
> I can't talk about "proper", I have never had proper training, but I can
> tell you what I would do.
> Give something like this a shot.
> DEFINE VARIABLE type AS CHARACTER INITIAL "PACK, BEND" NO-UNDO.
> IF Eff < 80 AND LOOKUP (JobOper.OpCode, type) > 0 THEN DO:
> You can simply add more comma separated items to the variable to
create more
> compare statements.
> Also...I find this very effective in setting up case statements.
> For instance, I print a different label upon receipt based on the
type of
> receipt...
> "PUR-UKN,PUR-STK,PUR-INS,PUR-MFG,PUR-SUB" NO-UNDO.
> DEFINE VARIABLE c AS INTEGER INITIAL 0 NO-UNDO.
> c = LOOKUP (RcvDtl.ReceivedTo, type).
> CASE c:
> WHEN 0 THEN
> WHEN 1 THEN...
> WHEN 2 THEN...
> OTHERWISE...
> END CASE.
> One trick with Case statements that I have found is that I can't get
it to
> recognize more than one statement per case, so I tend to enclose
everything
> within each case (WHEN...) inside an IF statement, unless I only
have one
> statement anyway.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
Behalf Of
> RICH WAGNER
> Sent: Monday, August 21, 2006 10:05 AM
> Subject: [Vantage] Multiple comparisons in BAM
> I am trying to write a BAM that will send and email to the Manager
based
> on the JobOper.OpCode. Each Manager is in charge of several
workcenters
> so I am trying to write an IF statement like the following.
> IF Eff < 80 AND JobOper.OpCode = ["PACK","BEND"]
> THEN DO:
> I could write a bunch of OR statements but I would rather not.
> Does anyone know the proper syntax to use in this situation?
> Thanks,
> Rich
I am trying to write a BAM that will send and email to the Manager based
on the JobOper.OpCode. Each Manager is in charge of several workcenters
THEN DO:
Rich
Rich,
You can simply add more comma separated items to the variable to create more
compare statements.
For instance, I print a different label upon receipt based on the type of
receipt...
CASE c:
WHEN 0 THEN
WHEN 1 THEN...
WHEN 2 THEN...
OTHERWISE...
END CASE.
One trick with Case statements that I have found is that I can't get it to
recognize more than one statement per case, so I tend to enclose everything
within each case (WHEN...) inside an IF statement, unless I only have one
statement anyway.
Good luck,
Aaron Hoyt
Vantage Plastics
RICH WAGNER
THEN DO:
Rich
Aaron
CASE c:
WHEN 0 THEN
WHEN 1 THEN DO:
This stament.
That stament.
END.
END.
OTHERWISE...
END CASE.
> Rich,
create more
> compare statements.
type of
> receipt...
> CASE c:
> WHEN 0 THEN
> WHEN 1 THEN...
> WHEN 2 THEN...
> OTHERWISE...
> END CASE.
it to
everything
have one
> statement anyway.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
Behalf Of
> RICH WAGNER
based
workcenters
> THEN DO:
> Thanks,
> Rich
