Multiple Customizations for single MES button
The reason that works for shift start is because it is actually part
of the main MES. When you use the process calling(like when
launching ReportQty) As long as you are calling the App from the
same place the same customization will always launch.
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
wrote:
> I believe if you name the MES Report Qty customization the same as
your
> main UD MES customization, it'll work. I had to do this with my
> customization to suppress the Shift Select screen.
> Vic
> -----Original Message-----
Behalf
> Of Michael McWilliams
> Sent: Tuesday, December 16, 2008 9:32 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Mulitple Customizations for single MES button.
> Just went to deploy a new MES customization & have hit a bump. I
> have 2 versions of MES & Report Quantity but I can only set it up
to
> launch one reportQTY. My different MES customizations launch
based on
> the config file for the local PC. But I have to launch Report
Quantity
> using sub process & process calling. Thats where I am stuck. I
have
> not seen anybody do this. If I have to I am going to try creating
one
> customization that is changed on form load based on user ID. But
I
> would prefer to keep two distinct custimizations.
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
have 2 versions of MES & Report Quantity but I can only set it up to
launch one reportQTY. My different MES customizations launch based on
the config file for the local PC. But I have to launch Report Quantity
using sub process & process calling. Thats where I am stuck. I have
not seen anybody do this. If I have to I am going to try creating one
customization that is changed on form load based on user ID. But I
I believe if you name the MES Report Qty customization the same as your
Vic
