Multiple MES sessions open needlessly
If you find Marks solution effective, please let us know. I would love
to add a feature like that
We tried the training route first, but with 5 to 10 new employees a week
(many only staying for the day and most gone before the weekend) we
found that insufficient alone.
We have gone to great lengths to error proof the system including the
following solutions that have worked in addition to the training:
1. Remove the shop floor icon from the desktop and start menu and use
gpedit.msc to tie down access to most everything.
2. Add MES to the registry to load on startup (without the icons, you
must reboot to get Vantage back up if closed).
3. Customized the MES screen to remove close button and remove the
ability to rip off tabs.
4. Created process driven automatic labeling that we require via ISO
based on reporting via MES (can't be prevented and must be entered to
get required labels).
5. Installed VNC for remote access to allow problem fixing without being
physically present at the machine (also allows remote control of several
machines from single desktop to make restarting database and upgrades
much easier.
If you would like more details on any of these, let me know.
Aaron Hoyt
Vantage Plastics
Mark Wonsil wrote:
> > I think Brad's question is that when shop floor users come up to
> > terminal, the MES window is minimized, and instead of checking to
> > it is already open, they just click on the icon, which opens a new
> > instance of the MES client.
> There are program launchers that can restrict a program to a single
> instance. I'm sure you can find a free one but here's a shareware version
> that should fit the bill.
> http://www.p6c.com/Products/P6Just1.html
> <http://www.p6c.com/Products/P6Just1.html>
> Mark W.
Here is hopefully a simple question to this very helpful group.
We are deploying MES (Vantage 8.03.404b)to our plants. What we are
seeing quickly that people are starting new sessions of MES instead
of pulling up the current minimized session.
The effect is that multiple MES sessions are open needlessly, which
we think is using up multiple licenses also and can affect the
computer performance, etc.
Of course we are attempting to train our operators also, but were
looking to mistake-proof this.
Is there a way to set an MES client to only pull up one session or
to maximize the current open session first?
Thanks to all,
Brad Boes
Metalworks
You only need one MES session per winterminal or PC open. Log in using the generic shop userid.
This then allows your employees to clock in and out (by entering their employee number) as needed - all sharing the same MES instance.
--- On Wed, 8/6/08, brad_boes <bboes@...> wrote:
Subject: [Vantage] Multiple MES sessions open needlessly
Date: Wednesday, August 6, 2008, 11:19 AM
Thanks to all,
Brad Boes
Metalworks
I think Brad's question is that when shop floor users come up to the
terminal, the MES window is minimized, and instead of checking to see if
Presumably you are using a shared "shopfloor" Vantage account to
authenticate the MES session to Vantage. There is a flag in the user
account record (under User Security maintenance) on the Security tab
(strange place for it) labled "Allow multiple sessions". You could
disable this and at least Vantage would complain if they tried to
startup another session. However this would mean that your shared
shopfloor account could only logon once, which would require you to have
a separate logon per station.
There is a flag in the default.mfgsys file called EnterpriseProcessing
that is supposed to control this behavior:
EnterpriseProcessing Whether multiple concurrent sessions are allowed on
the
workstation. The choices are true or false (the default).
But as far as I can tell it doesn't have any effect.
-brian
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Robert Brown
Sent: Wednesday, August 06, 2008 3:36 PM
Subject: Re: [Vantage] Multiple MES sessions open needlessly
<mailto:bboes%40metalworks1.com> > wrote:
From: brad_boes <bboes@... <mailto:bboes%40metalworks1.com>
Thanks to all,
Brad Boes
Metalworks
OK, so my response is not going to be nearly as helpful as Brian's,
but we have two PCs in our shop that are always logged on to MES
using the same log-in ID. The only thing I could suggest (and yes it
is a very stupid suggestion, so please forgive me) is to tell the
employees to not minimize MEs. That way, when they come up to use
the PC, it is already up on the screen.
Sorry that I couldn't be of more help.
--- In vantage@yahoogroups.com, "Brian W. Spolarich "
the
see if
user
have
allowed on
> the
> -brian
Photonix /
> Picometrix
Behalf
> Of Robert Brown
using
their
> Thanks to all,
> Brad Boes
> Metalworks
You could create your own application to start MES. Then have your application check to see if it is running or not. If not running already, start it. And if its not running, popup a message that MES is already running on the computer, or make MES the active application and set focus to it.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Sean Toler
Sent: Thursday, August 07, 2008 6:19 AM
Subject: [Vantage] Re: Multiple MES sessions open needlessly
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Brian W. Spolarich "
the
see if
user
have
allowed on
> the
> -brian
Photonix /
> Picometrix
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
> Of Robert Brown
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
using
their
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com>
> Thanks to all,
> Brad Boes
> Metalworks
Thank you to all,
With the options returned in this post we should be able to get this setup
better for the shop floor.
We do have separate and automatic logons for each MES shop terminal. So the
"allow multiple sessions" checkbox is our starting point, but we will want
to evaluate the other options for the office group also.
Thanks again!!
Brad Boes
Corporate Technology Manager
Metalworks, Inc.
email: bboes@...
voice: 231-845-3130
cell: 231-690-5091
fax: 231-845-1043
Not a 'Stupid suggestion' Sean... A very good one.
Just have the manager spend some time with the people and who them how much EASIER it is for the users to bring an existing minimized MES app to fullscreen versus going through the entire load/login/load process.
People appreciate it when you treat them like they are too dumb to learn.
If the users are making innocent errors like this, they are going to make errors using the applications in MES to an even higher degree.
Invest the time know to establish trust that they will get help and training (on the spot) when needed. You will soon find they much more often seek it out when they are unsure (and save lots of non-value added time by entering transaction correctly the first time).
Give your shop people some credit for being able to learn.
Rob
Date: Thursday, August 7, 2008, 7:18 AM
--- In vantage@yahoogroups .com, "Brian W. Spolarich "
the
see if
user
have
EnterpriseProcessin g
> EnterpriseProcessin g Whether multiple concurrent sessions are
allowed on
> the
> -brian
Photonix /
> Picometrix
> bspolarich@. .. ~ ~
> www.advancedphotoni x.com
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
> Of Robert Brown
> To: vantage@yahoogroups .com
using
their
> <mailto:bboes% 40metalworks1. com> > wrote:
> From: brad_boes <bboes@... <mailto:bboes% 40metalworks1. com>
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Thanks to all,
> Brad Boes
> Metalworks
Mark W.
I solved that by using Windows group policy.
No task bar means they can't open another instance, but they can always reboot the terminal because we have MES run as a service.
----- Original Message ----
Sent: Friday, August 8, 2008 8:46:27 AM
Subject: RE: [Vantage] Re: Multiple MES sessions open needlessly
http://www.p6c com/Products/ P6Just1.html
Mark W.
Tony,
How did you add MES as a service?
Jacob Dybala
Director of Information Technology
IMS Companies, LLC
Office: (847) 391-8123
Fax: (847) 391-8358
Cell: (847) 812-3037
E-mail: jdybala@...
Sent: Friday, August 8, 2008 9:11:10 AM
Subject: Re: [Vantage] Re: Multiple MES sessions open needlessly
Mark W.
