Hello all,
We are on 8.03.408B and have a question as to how others are handling
this situation, we have a piece of material that when cut creates the
base material for 3 different parts. We currently issue the material to
the assm 0 level of the job and have two subassemblies for the other two
parts but all of the cost is ending up on the level 0 part?
We would appreciate any suggestions.
Paul E. Pachniak
Controller
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 3114
Fax: 262-252-4974
Email: paul.pachniak@...
<mailto:paul.pachniak@...>
WWW: http://www.aceprecision.com <http://www.aceprecision.com>
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
Paul E. Pachniak
Controller
Fax: 262-252-4974
