Thanks Brian, you have cleared that for me, you have been a good help.
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> Terminal Server is (sort-of) included with Microsoft Windows, its really
> a licensing issue not new software. Choose Remote Desktop Connection
> (start menu -> accessories), enter a server name, and you're (sort-of)
> using terminal server. Windows servers typically allow 2 or 3
> connections, to get more you need to buy "Terminal Server licenses" to
> allow more people to connect.
> We use it today for our remote locations, for Vantage 6.1 and Epicor
> 9.05 in testing, I'm sure that 8.03 would work. We have a separate
> server with the client installed, and people remote into that instead of
> the main Vantage server. The only configuration required was creating a
> tiny script that starts Vantage then logs out afterwards, and setting
> the user account details to automatically run that script.
> Brian.
> Of michael.hutcheson@...
> Sent: Wednesday, February 16, 2011 10:38 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Multiple plants
> Hi Jason,
> Thank you for your reply.
> We are using Vantage 8.03.406 on Win 2003 R2 server, Progres Backend. Is
> this version compatible with Terminal Server?
> Regards,
> Michael
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> Jason Claggett <jason@> wrote:
> > Michael,
> > Not sure of your setup, but we find that using Server 2008 R2 and
> publishing the app (available starting with 2008 Server) you can publish
> the Epicor icon pretty much across the globe and the processing happens
> all on the terminal server. Of course you will need terminal server
> licenses and setup of local printers if that is available, but the
> flexibility and the speed increase is well worth any initial headaches.
> > Thanks,
> > Jason Claggett
> > Microsoft Small Business Specialist
> > MCP #3856159
> > 2W Technologies, LLC
> > Epicor Silver Partner
> > 312.533.4033 x8039
> > jason@<mailto:jason@>
> > [cid:image003.jpg@]
