Multiple qtys for different Job assemblies
You could also "auto-receive" the widget job to stock and "backflush" them
to the "ABC" & "XYZ" jobs to eliminate the manual transactions. Warning!!!
do not "auto-receive" the widgets unless they are a standard cost part.
Greg Clauser
Lakin General Corporation
773-871-9604 FAX: 773-871-1265
Sent: Wednesday, February 14, 2001 11:18 AM
Subject: Re: [Vantage] Multiple qtys for different Job assemblies
Amy:
That's precisely how I handle it. There's no law that says you must make a
make-to-stock (m-t-s) job and keep qty on the shelf.
I have found that its been awfully handy to have 1 or 2 of those repeaters
on
hand once in a while.
In either case, you only need one traveler for as many widgets as needed,
and
can still apply the cost to as many m-t-o jobs as necessary.
Rick Gors
MR/MMIS
Osco
Amy Mackay wrote:
> Here's my scenario. Any suggestions would be greatly appreciated.
> Job TEST
> (level one) Assy 1 - ABC assembly qty=1
> (level two) Assy 2 - widget qty=2
> (level one) Assy 3 - XYZ assembly qty=1
> (level two) Assy 4 - widget qty=4
> So in this case, I want to make six [6] widgets for this one Job, but I do
> not want to track two different drawings and travellers, and post labor to
> two different subassemblies, issue material twice, etc.
> We currently make everything directly to the Job b/c we make custom
> machinery where not many parts repeat. Now we're getting into more repeat
> parts, so this is becoming an issue. But it's not nearly make to stock...
> We're considering making a separate stock Job for these parts that repeat,
> and just selecting these repeating parts in the original Job to be pulled
> from stock. This will require an additional step to receive from mfg and
> issue to the Job (all in Receipts to Mfg).
> Anyone dealing with this? How do you handle it? Thank you.
> Amy T. MacKay
Job TEST
Amy T. MacKay
Parkinson Technologies
amackay@...
(p) 401-762-2100 x 324
(f) 401-762-2295
Amy:
I have found that its been awfully handy to have 1 or 2 of those repeaters on
In either case, you only need one traveler for as many widgets as needed, and
Rick Gors
MR/MMIS
Osco
> Job TEST
> Amy T. MacKay
> amackay@...
> (f) 401-762-2295
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@egroups.com
