LeAnn
below is my codes for the Requisition. follow the format and change to what is needed in your case. If you need furthur help, let me know.
{ud/GlbAlert.i &TableName = "reqhead"}
DEFINE VARIABLE NewEmailBody AS CHARACTER NO-UNDO.
FIND userfile WHERE (userfile.dcduserid = reqhead.requestorid) NO-LOCK.
FIND reqdetail WHERE (reqhead.company = reqdetail.company) AND
(reqhead.reqnum = reqdetail.reqnum) NO-LOCK NO-ERROR.
/* Create email */
ASSIGN Email-To = STRING(userfile.emailaddress)
Email-Subject = "Requisition number: " + STRING(reqhead.reqnum) + " has been submitted"
/* Create the new body of the email */
NewEmailBody = "~nRequisition number: " + STRING(reqhead.reqnum)
+ "~n~nRequested By: " + STRING(userfile.name).
ASSIGN NewEmailBody = NewEmailBody
+ "~n~nRequisition Status: Waiting For Approval!".
+ "~n~n-----------------------------------------------------------------------------------".
+ "~n~nYour requisition has been submitted and is waiting for approval."
+ "~n~nYou will get another notification once your requisition status has changed."
+ "~n~n----------Summary of this Requistion: -------------------".
FOR EACH reqdetail of reqhead no-lock:
Assign NewEmailBody = NewEmailBody
+ "~n~nItem " + STRING(reqdetail.reqline) + ": "
+ STRING(reqdetail.PartNum) + " " + STRING(reqdetail.LineDesc)
+ " - Qty: " + STRING(reqdetail.OrderQty)
+ "~n".
END.
+ "~n~nDO NOT REPLY TO THIS E-MAIL ACCOUNT, IT DOES NOT GET REVIEWED!".
/* Print Email Body */
ASSIGN Email-Text = NewEmailBody
Lam
/* Create email */
+ "~n".
END.
Lam
--- In vantage@yahoogroups.com, "leann_37" <lmarruffo@...> wrote:
> My global alert isn't working, and I don't know why.
> Any assistance would be appreciatedÂ…
> {ud/GlbAlert.i &TableName = "RcvDtl"}
> FIND POHeader WHERE (RcvDtl.PONum = POHeader.PONum) NO-LOCK.
> If POHeader.Termscode = "N05"
> THEN
> DO:
> ASSIGN Email-Text = "PO Number " + string(RcvDtl.PONum) + " Line Number " + RcvDtl.POLine + " Release Number " + RcvDtl.PORelNum + " has been received. Terms are net 5" + ".~n~n".
> END.
> ELSE DO:
> Return "CANCEL SEND":U.
> END.
> It's definitely because I am trying to read a terms code from POheader, while the BAM is assigned to RcvDetail (which doesn't have terms code), but I don't what the syntax should be to look up in one table from data read from another.
> The error is 4GL STOP condition: The Server application has returned an error. (7243) (7241)
> And references a boolean field, so it's got to be that terms codeÂ…
> This is so embarrassing...
> Thanks in advance!
> - leAnn
