Mystery Orphan PO?
I’ve got about 100 Orphan POs in our Generate PO Suggestion Log, some very recent. I can’t figure out why they are orphaned.
In checking a simple part:
  • The PO Release Job/Asm/Mtl qty matches the Job/Asm/Mtl qty.
  • PO is closed.
  • Material has the green checkbox on the job.
  • Job is open.
There is an entry in the Job change log where the original material seq# was deleted. Another material was added in the same spot. But then 3 days later the PO was cut; everything lines up currently…
Any ideas why it is still being seen as orphan? Thanks!
FYI I can’t find anything in Epicor help. Below best info I could find but doesn’t explain my issue…
I’m seeing that PORel.PORelOpen and PORel.OpenRelease sometimes don’t match. Anyone know the difference between the PORelOpen and OpenRelease columns?
Descriptions listed in Extended Properties Maintenance don’t help.
I have 164,000 lines where the two columns match, and ~1000 where they don’t (1 and 0 or 0 and 1).
If curious…
select t1.PORelOpen, t1.OpenRelease, * from POHeader t0
join PORel t1 on t1.Company = t0.Company and t1.PONum = t0.PONum
where t1.PORelOpen <> t1.OpenRelease
Edit - PORelOpen looks to be unused currently. It’s set to 1 on some old POs, but is set to 0 on all new POs, regardless of status.
Alright I think I got to the bottom of it. In addition to Open POs on Closed Jobs, I’m seeing these also count as orphan:
  • Open PO, Open Job, but Closed Order Release
  • Open PO, Partially Received, and PO is Past Due.
