So I have a custom layer on Order entry that basically makes everything read only except for a UD field and promisedate which I’m doing with a Data rule with an except column exemption. Oddly, with this in place the line navigation control is disabled as well.
Any ideas? Even in Order Tracker this control is available.
I’ve tried adding orderline to the columnlist and that didn’t seem to have any affect.
I’m curious if the navigation keyboard shortcuts (Ctrl → and Ctrl <–) still work when that control is disabled?
I’m not suggesting keyboard shortcuts as a workaround, that would be a rotten thing to do to users. I’m curious though if disabling the control might be a way to prevent normal text entry navigation from context switching and disposing work…
