Need help running endact.r
Here is a response from Epicor that applies if you are running version or
later:
Below that is for version 6.1 before 535
Created a call per your email, after version 6.10.535 you can run the
endact.r from data conversion, please see below
Summary: DC Database Conversions 7,428 and 7429 Replace Endact.r
and Clockout.r
Book: Support Solutions
Page: 6595MPS
PROBLEM DESCRIPTION:
Endact.r and Clockout.r are needed to remove active labor header and detail
transactions that cannot be manually removed.
PROBLEM RESOLUTION:
Version 6.10.535 has added the following database conversion programs under
the System Management>Utilities folder:
7,428 - End Activity on Labor Detail Transactions - cv/cvjc0050.w 7,429
- End Activity on Labor Header Transactions - cv/cvjc0051.w
Conversion Program 7,428, End Activity on Labor Detail Transactions, is the
replacement for the Endact.r program as this allows you to change the active
labor detail transaction from Yes to No to log the user out of the job
operation transaction that they were stuck on.
Conversion Program 7,429, End Activity on Labor Header Transactions, is the
replacement for the Clockout.r program as this allows you to change the
active labor header transaction from Yes to No to log the user out of data
collection and their active time card record.
INSTRUCTIONS FOR RUNNING CONVERSION PROGRAMS:
Conversion Program 7,428 - End Activity on Labor Detail Transactions 1.
Go to System Management>Utilities>Database Conversions. 2. Highlight
7,428 - End Activity on Labor Detail Transactions and choose
Conversion>Run Conversion Program. Say Yes to the Are You Sure message.
3. Type in your Company ID and the Employee ID number and click the Get
Detail Transactions button. You should see the active job detail
transaction with a status of YES. Type NO in the Active column. 4.
Click Done.
Conversion Program 7,429, End Activity on Labor Header Transactions 1.
7,429 - End Activity on Labor Header Transactions and choose
Transactions button. You should see the active time card transaction with a
status of YES. Type NO in the Active column. 4. Click Done.
Before Version: 6.10.535
Install the program by copying the attached ENDACT.R file to your \mfgsys61
directory.
To run the program.
1) It is highly recommended that you run this fix program on a test copy of
the database
before you run it on your live database.
2) It is also recommended that you make a current backup of the live
database before running
this program on the live database.
3) Start a Vantage session.
4) Select menu options: Vantage Basic -> Command Window.
5) In the command windows key the command EDITPROG and press ENTER.
6) In the Procedure Editor window enter the command RUN ENDACT.R and press
F2.
7) The program will then prompt for your Vantage Company ID/ and Employee
ID.
8) Each active labor transaction for this employee will then be displayed.
9) Change the ActiveTrans field to NO on each transaction.
10) After clocking the employee out for the day, use Labor Entry to
review/correct transactions.
11) The program will end by displaying a completion message.
12) File|Exit|No to save changes when leaving the procedure editor window.
_____
Michael
Sent: Wednesday, September 19, 2007 4:33 PM
Subject: [Vantage] Need help running endact.r
I have recently taken over as the system administrator at my company.
We have a user hung in data collection and I have been able to
determine that I need to run endact.r to get them 'unhung'. My
question is, how do I run endact.r?
Any help you can provide would be appreciated.
Thank you,
Mike
Thank you,
Mike
Mike:
If you are on 6.10. 542 the tool or programs you need to run are already there. Go into System Management then into Utilities then into Database conversion. Scroll until you find program 7428 and run it, after that run 7429 that should clear the user.
Tim Clark
Manager, Information Technology
General Sheet Metal Works
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Michael
Thank you,
Mike
