Need help with V6.x to E9.x Open Job Conversion
We have a similar number of jobs and are currently planning our conversion from 6.1 to 9 although we are also merging the data from 4 companies in 6.1 to 1 company in 9. Our approach involves using ODBC (MS Access) to extract the data and handle any mapping then use DMT to import the data to 9.
Chris
Chris HenzelEpicor 9 Project ManagerTel: +44 (0)1582 436150Mob: 07836 314164
This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this email. Please notify the sender if you have received this email by mistake and delete it from your system.Email transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender does not accept liability for any errors or omissions in the contents of this message, which arise as a result of email transmission. Registered Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England. Tel: +44 (0)1582 731144. Company No. 3450138.
From: vantage@yahoogroups.com on behalf of Moore, Jim (Anniston)
Sent: Mon 25/10/2010 19:30
Subject: [Vantage] Need help with V6.x to E9.x Open Job Conversion
We are a large machine shop that has many open Production Jobs at any
one time (couple of thousand).
We are currently on Vantage 6.1 and working on a re-implementation to
Epicor 9.xx.
Has anyone done a Data Conversion of open Production Jobs from Vantage
6.x or higher to convert into Epicor 9.xx?
Manually converting / entering them is not an option.
Any help or advice would be appreciated.
Jim
Epicor 9.xx.
Jim
