Need Progress help Please
Thanks for you response but that doesn't seem to be the problem. It still
only comes out for the company I am currently in. Now there is a situation
that if the employee has the same Id in two different companies (we do have
that where we terminated out of one company and transferred to another) then
this will export both companies for that employee but only that employee
Sent: Monday, October 01, 2001 7:10 PM
Subject: Re: [Vantage] Need Progress help Please
Hi Rhonda.
There is nothing the code you posted that would select only one
company. However they would come out intermixed. I have added a line to
the "For each" below that will sort them by company, then by employee
ID.
HTH.
"Reilly, Rhonda" wrote:
> Following is the progress code that is created by results. I adapted this
> to output a comma delimited file that I have linked in an access program.
I
> run this from a menu item in Vantage. What I really need this to do is to
> pull all records from each company at once. We have 3 companies within the
> database. This will only pull from the company in which I am logged into.
> Is there a way for me to be able to do this.
> Thanks
> Rhonda
> P.S. I took the one line out of this that makes it override the triggers
> just in case it ends up going to someone that is shouldn't
> DEFINE VARIABLE qbf-count AS INTEGER NO-UNDO.
> DEFINE VARIABLE qbf-governor AS INTEGER NO-UNDO.
> DEFINE VARIABLE qbf-govcnt AS INTEGER NO-UNDO.
> DEFINE VARIABLE qbf-loop AS INTEGER NO-UNDO.
> DEFINE VARIABLE qbf-time AS INTEGER NO-UNDO.
> DEFINE BUFFER PREmpMas FOR dcdv7.PREmpMas. /* you can safely delete this
line */
> ASSIGN
> qbf-count = 0
> qbf-governor = 0
> qbf-time = TIME.
> OUTPUT TO \\mobile_app\otec\hrprogram\prempmas.dat.
> main-loop:
> FOR EACH dcdv7.PREmpMas NO-LOCK
> BREAK BY dcdv7.prempmas.company /* sort by comapny first */
by dcdv7.PREmpMas.EmpID:
> qbf-count = qbf-count + 1.
> PUT CONTROL
> '~"' dcdv7.PREmpMas.Company '~"'
> '~"' dcdv7.PREmpMas.EmpLink '~"'
> '~"' dcdv7.PREmpMas.EmpID '~"'
> '~"' dcdv7.PREmpMas.FirstName '~"'
> '~"' dcdv7.PREmpMas.MiddleInitial '~"'
> '~"' dcdv7.PREmpMas.LastName '~"'
> '~"' dcdv7.PREmpMas.Name '~"'
> '~"' dcdv7.PREmpMas.Address '~"'
> '~"' dcdv7.PREmpMas.Address2 '~"'
> <<<<<<The rest of the fields.>>>>>>
> CHR(13) CHR(10).
> END.
> RETURN.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Specialists in Progress Databases and Software since 1986
William E. Colls william@...
PROComputer Systems Tel 613 591 0079
67 Willow Glen Dr. Fax 613 591 3924
Kanata Ontario Canada www.procomsys.com
K2M 1T1
to output a comma delimited file that I have linked in an access program. I
Rhonda
ASSIGN
qbf-count = 0
qbf-governor = 0
qbf-time = TIME.
main-loop:
BREAK BY dcdv7.PREmpMas.EmpID:
PUT CONTROL
CHR(13) CHR(10).
END.
RETURN.
Hi Rhonda.
ID.
HTH.
> Thanks
> Rhonda
> DEFINE BUFFER PREmpMas FOR dcdv7.PREmpMas. /* you can safely delete this line */
> ASSIGN
> qbf-count = 0
> qbf-governor = 0
> qbf-time = TIME.
> main-loop:
> PUT CONTROL
> CHR(13) CHR(10).
> END.
> RETURN.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
K2M 1T1
