Create a resource group with $0 costs for both labor & burden, setup &
production and quoting. Example: Engineering. Use the appropriate
calendar for the resource group (probably not the same as the shop
calendar).
Create a resource or resources for the responsible area(s). Example -
Engineer.
Create an Operation Mater of Review CAD Dwgs and tie the operation to
the resource/resource group required.
Add/drag operation to method or job with appropriate amount of fixed
hours to be allotted as the operation standard.
Schedule the job. It will account for the fixed number of hours in the
operation and calculate the start date of the first operation.
By adding this to your method, once this op is completed, someone should
use labor entry, office MES, shop MES or Job adjustment to indicate that
the operation has been completed otherwise you will have a scheduling
dilemma. The benefit by doing it is that you now who performed the task
as if it were a shop floor operation. Whoever the shop employee is, you
will want to make sure the shop labor rate for that employee is $0 or
you will result in a job cost.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant.com <http://www.vistaconsultant.com/> /
www.2WTech.com
Of Vic Drecchio
Sent: Friday, December 12, 2008 9:02 AM
Subject: [Vantage] Need Scheduling Suggestion
TGIF!
Can someone please offer a suggestion on how I could accomplish this?
I'd like to set up an Operation that is solely used as "Queue Time" or
simply a placeholder for time without any cost accumulations or impact.
Here's what we'd use it for: Our manufactured assemblies that go into
our top Part/Kit each require varying timeframes for the overall
research and part procurement process or engineering processes. I
simply want an operation on a job that is a time holder that will allow
more accurate scheduling times for these manual processes.
For example, Op Seq 40: Review CAD drawings for subassemblies (4 hours)
I don't want Setup time because that has costs associated with it.....
these are non-cost/non-burdened items.....
Any ideas?
Thank you in advance!
Vic Drecchio
ERP Administrator
TIMCO Aviation Services
Greensboro, NC
Email: vic.drecchio@... <mailto:vic.drecchio%40timco.aero>
Office: 336.668.4410 x3091
Mobile: 704.530.3092
calendar).
Engineer.
Charlie Smith
www.2WTech.com
Of Vic Drecchio
TGIF!
Any ideas?
Vic Drecchio
ERP Administrator
Greensboro, NC
