.NET Framework error
The dashboard is developed through an RDP server enviroment and not on a local E9 client.
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> Sounds like something outside your customization. But it could be an issue
> with DEP if you built the dashboard outside of the normal Epicor methods.
> If you disable DEP and that fixes the error, it's an issue with NX
> compatibility. You can disable this when building an app, but doing it for
> your dashboard is a whole other can of worms.
> On Tue, Apr 9, 2013 at 4:18 PM, cchang015 <cchang@...> wrote:
> > We received the following error message when trying to print from a custom
> > dashboard. Has anyone seen this error message or know what it means?
> > "Attempted to read or write protected memory. This is often an indication
> > that other memory is corrupt."
We received the following error message when trying to print from a custom dashboard. Has anyone seen this error message or know what it means?
"Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
