New menu option "multi-company direct server watchdog"
FYI.
Just poking around in 2025.2 and found this menu option.
For all those people who have to drop into SQL to clear hung tasks this could be a god send. Sounds like it is intended to run unattended after hours!
Please check KB0146793 for details.
I’m not seeing it in my on-prem instance - can you provide another clue ? :slight_smile:
(The KB doesn’t mention version specifics)
I’m on patch 26 so maybe it came in on a patch. Which are you on?
I am sure it is all meticulously noted on the release notes for each patch! :slight_smile:
The parameters don’t even include a log destination so we might want to treat this as beta software until it is proven that it works. Might want to wait until you have a hung multi-company job and then run it to see if it fixes it. Having this running all the time might be risky without some kind of log to alert you to corrections.
Interesting that the KB note talked about a feature (Cancel Stalled Task ) in the original process that does not work so they just created a new process. I could not even find Cancel Stalled Task as an option on my Multi-company Direct process so maybe this has already been removed.
15, but now I’m trying to get to 26
Could not see anything in the release notes although there was a lot of work on the Multi-company direct process so far in 2025.2 to patch 31. I wonder if errors as part of those changes finally motivated them to build this utility.
