Sure, active directory doesn't take much to run, but to be on the
safe side I'd make sure to have a good amount of hard drive space on
the system drive (20 gb to be safe, where active directory usually
is). Older servers tend to have that problem.
--- In vantage@yahoogroups.com, "Mark Tellefson" <mtellefson@...>
wrote:
>department
> Thanks for your thoughts Paul. As a self-taught, one man IT
> I always welcome as much information I can get.with
> I got a call back from Epicor. They are sending me their
> recommendations for a new Vantage server. He said I could get away
> putting Service Connect on our old engineering server (SDRC02) sincecontroller?
> there won't be much else going on with that server. I would look at
> adding another processor and increasing RAM to 4G.
> Would it be worth running our older ML370 as a backup domain
>Behalf
> Of Paulcontroller.
> Sent: Tuesday, November 25, 2008 9:41 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: New Vantage server recommendations
> Here are some thoughts:
> One thing that jumps out is that you only have one domain
> I'd get another one seeing as they cost nothing (1 grand for thetheir
> hardware and 1 grand for the software (win2003)) and now you have
> double the redundancy in that arena.
> The funny thing about Epicor and their recommendations is that
> instruction manuals always warn you to seperate server roles butare
> written assuming you are using one server.AQM.
> You didn't specify the version of vantage you are using, I'm on
> Vantage 8.3 here and the server is a :
> Two Xeon E5440 2.83 GHZ (quad core)
> Win 2003 Enterprise
> 12 gb of ram
> Raid 0+1
> Basically it was bought (before my time here) along the exact specs
> provided by Epicor for Vantage 8.3
> The server is currently running Vantage 8.3, Service Connect and
> I have 70 users on Vantage, and very few users on AQM. I installedslow
> AQM and SC on the same server because at the time I didn't have
> another avaiable for this purpouse.
> Right now the server is using 4gb of memory. Users still report
> times, although personally I think it works quite fast. When a usermy
> tells me that a report takes 20 seconds to come up I think back to
> Oracle based erp days and think that's lightning fast.Vantage
> Vantage is an odd beast, I'm used to working with microsoft and
> oracle based products which will take all that you give them,
> seems to take what you let it take (through the use of the Progressthe
> Explorer configuration tool).
> For your situation I'd probably get more memory for the new Vatnage
> server (get Enterprise edition to do this), get a thousand dollar
> backup domain controller (can also use it to replicate files from
> other file servers as another form of redudnancy), and possiblydidn't
> another thousand dollar server to do service connect if you want to
> do things "without breaking any rules"
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "rapat_mark" <mtellefson@> wrote:
> > I have been breaking the rules for a couple years although I
> > even know it until becoming part of this group. Our currentVantage
> > install is running on a server that has a whole bunch of otherdepartment
> > responsibilities.
> > I asked this same question of my account manager but would be
> > interested in any input from those of us in the real world.
> > We currently have 4 servers running as follows
> > "Main-Server" (Vantage, domain controller, file server, print
> server,
> > DHCP, DNS)
> > Compaq Proliant DL380
> > Qty 2: Xeon 3.2Ghz
> > 3.5G RAM
> > Server 2003
> > "SDRC02" (file server for Eng files, SDRC I-deas server (limited
> use))
> > This server runs our old engineering software that has limited use
> > but still needs to remain running.
> > Compaq Proliant DL380 G4
> > Xeon 2.8Ghz
> > 3G RAM
> > Server 2000 (will be upgraded to 2003)
> > "SW01" (Solidworks)
> > Compaq Proliant DL380 G5
> > Qty 2: Xeon 5110 1.60 Ghz
> > 4G RAM
> > Server 2003
> > "Exchange" (Exchange 2003)
> > Compaq Proliant DL360 G4p
> > Xeon 3 Ghz
> > 3G RAM
> > Server 2003
> > I also have an older ML370 933Mhz with 768M RAM that is not being
> used.
> > We currently have 16 Vantage users, 7 MES users and Service
> Connect.
> > The standard users may grow slightly as we get our Sales
> > more involved in Vantage.of
> > I am looking at proposing a new server for Vantage use and would
> like
> > recommendations for the new server and also for better use of our
> > current servers. I have seen references that SC should run on it's
> > own server and I am wondering if that could be combined with one
> > these other servers as well.
> > Mark Tellefson
> > IT Manager
> > Rapat Corporation
> > (218) 483-3344
