NExt menu id
When in Menu maintenance, adding a dashboard for example, we precede our menu ids with UD. But I don’t seem to have an easy way to find the next available menu ID. Any suggestions?
Is there a reason why you couldn’t create a BAQ to search for Menu ID’s starting with UD and sort by descending?
Yes I did that, but I once saw someone figure out the next one from within the Menu Maintenance screen. Was hoping I could find that again bu no.
If you really wanted to get fancy, you could create a “bump” function via customization to do just that, but it’s probably not worth the effort.
Adding this under the feature requests and suggestions group makes sense as it’s a very reasonable quality of life enhancement that would make life easier for anyone who works in menu maintenance. I’d mention the same functionality should be applied to seccodes as well as that can be a bit challenging at times too.
