Next Operation
Adam,
You can't join on a calculated field in Crystal, but you can use them in
record selection formula's. So you could say Calculatedfield =
Vantage.field for instance and it may accomplish a similar thing.
Troy
Sent: Saturday, November 01, 2003 12:12 PM
Subject: RE: [Vantage] Next Operation
Amy - is this a Crystal or RB report? I have always yearned for
solutions like Patrick's to work inside of Crystal, but Crystal does not
allow joining on calculated fields :(. If you are in Crystal, the only
solution I've come up with is to stick a subreport in and pass the next
operation back to the main report with a shared variable.
AE
On Fri, 2003-10-31 at 08:57, pjw@... wrote:
> Not a perfect solution but worth a try:
> create a calculated field adding 10 to the sequence number
> Add the joboperation table as an alias "joboper2", left outer join,
using
> the company, jobnumber, assebly sequence, and joboper2.operationsequence
to
> your calculated field.
> Patrick Winter
> From: Amy Creighton [mailto:acreighton@...]
> Sent: Thursday, October 30, 2003 7:38 AM
> Subject: [Vantage] Next Operation
> Has anyone found a way to list "next operation" in a report when the
next
> operation is in the parent assembly? We want to basically show the life
of
> the part. Thank you.
Yahoo! Groups Sponsor
Has anyone found a way to list "next operation" in a report when the next
operation is in the parent assembly? We want to basically show the life of
Amy T. Creighton
Engineering Manager
Parkinson Technologies
acreighton@...
(p) 401-762-2100 x 324
(f) 401-762-2295
Amy,
What is the relationship between the parent and sub-assemby. Is the sub
pulled as material or an assembly? If a material and MRP is creating
suggestions for the sub hobs, then you will not see the relationship to
the top level. However, if the sub is an assembly within the parent,
then a one-to-one relationship will exist between the two.
dave
David P. Utley
IS Manager
National Coupling Company, Inc.
1316 Staffordshire Road
Stafford, Texas 77477
Office: 281.499.2583
Fax: 281.499.5941
Direct: 281.208.6715
Cell: 281.352.2793
next
of
Amy T. Creighton
Engineering Manager
acreighton@...
(f) 401-762-2295
HYPERLINK
"http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705
007183:HM/A=1524963/R=0/SIG=12o885gmo/*http:/hits.411web.com/cgi-bin/aut
oredir?camp=556&lineid=3614674∝=egroupweb&pos=HM"
HYPERLINK
"http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egrou
pmail/S=:HM/A=1524963/rand=859553933"
and Crystal Reports and other 'goodies', please goto: HYPERLINK
"http://groups.yahoo.com/group/vantage/files/"http://groups.yahoo.com/gr
oup/vantage/files/.
(2) To search through old msg's goto: HYPERLINK
"http://groups.yahoo.com/group/vantage/messages"http://groups.yahoo.com/
HYPERLINK
"http://groups.yahoo.com/group/vantage/links"http://groups.yahoo.com/gro
up/vantage/links
Your use of Yahoo! Groups is subject to the HYPERLINK
"http://docs.yahoo.com/info/terms/"Yahoo! Terms of Service.
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.532 / Virus Database: 326 - Release Date: 10/27/2003
Outgoing mail is certified Virus Free.
Add the joboperation table as an alias "joboper2", left outer join, using
the company, jobnumber, assebly sequence, and joboper2.operationsequence to
Patrick Winter
Amy T. Creighton
Engineering Manager
acreighton@...
(f) 401-762-2295
AE
> Patrick Winter
