No Change Log for Price List Setup Program?
Ok, I know there must be a way to do this. I tried to create a subprocess
to call the change log entry program and then created a context menu to call
that process, but...it did not work.
Are there any other ideas out there for ways to make this happen.
Aaron
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
admundng
Sent: Friday, December 28, 2007 3:01 AM
Subject: [Vantage] Re: No Change Log for Price List Setup Program?
Hi Aoron,
I have tried added in PriceLst, PriceLstGroup or PriceLstParts table
in BAM. But how should i go to check my log file.
For instance customer screen, there have a log book icon to click at
the top menu.
How about price list and others???
Need help!!! Thanks.
Admund
--- In vantage@yahoogroups.com, "Tew L. P." <lptew@...> wrote:
> Hi Aaron,
> Many thanks for your great idea, we will try it out first and let
you
> know if we managed to create anything from there.
> Cheers!
> Tew
> --- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@> wrote:
> > Tew,
> > You should be able to create a change log using a BAM (Business
> Activity
> > Manager) on the PriceLst, PriceLstGroup or PriceLstParts tables
(at
> least in
> > 8.03.403).
> > It's fairly straight forward to set up when using a BAM to keep a
> log of
> > changes. I can't promise how it will turn out, but you should be
> able to
> > get there from here.
> > Good luck,
> > Aaron
On
> Behalf Of
> > Tew L. P.
> > Sent: Wednesday, December 26, 2007 10:36 AM
> > Subject: [Vantage] No Change Log for Price List Setup Program?
> > Hi all,
> > It was highlighted as one of the key features of Vantage in
> EPICOR's
> > Executive Overview presentation that Change Log is available to
> trace
> > any data changes by users or in another word, provide the Audit
> Trail
> > function. However, we just realized that there is no Change Log
> found
> > within the Price List Setup program.
> > Can anyone explain that?
> > Many thanks.
> > Tew
Hi all,
It was highlighted as one of the key features of Vantage in EPICOR's
Executive Overview presentation that Change Log is available to trace
any data changes by users or in another word, provide the Audit Trail
function. However, we just realized that there is no Change Log found
Many thanks.
Tew
Yeah: They'll say anything to push up sales (true or not) and then cry ignorance after you've purchased a module and their claims prove to be far more than the reality.
It is not a business paradigm that bodes well for them long term - but I suspect they don't care...
Seems very much a "pump & dump" mentality intended to drive up sales and increase user base (at any cost) to make them attractive to larger company that wants to buy a sizable share of the market via acquisition.
There are dozens & dozens of examples of it in the ERP market over the last decade - all with this very same behavior foreshadowing it.
Rob Brown
Hi all,
Many thanks.
Tew
Never miss a thing. Make Yahoo your homepage.
Tew,
You should be able to create a change log using a BAM (Business Activity
Manager) on the PriceLst, PriceLstGroup or PriceLstParts tables (at least in
8.03.403).
It's fairly straight forward to set up when using a BAM to keep a log of
changes. I can't promise how it will turn out, but you should be able to
Good luck,
Aaron
Tew L. P.
Hi all,
Many thanks.
Tew
Hi Aaron,
Many thanks for your great idea, we will try it out first and let you
Cheers!
Tew
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> Tew,
Activity
least in
> 8.03.403).
log of
able to
> Good luck,
> Aaron
Behalf Of
> Tew L. P.
> Hi all,
EPICOR's
trace
Trail
found
> Many thanks.
> Tew
Hi Aoron,
the top menu.
Admund
> Hi Aaron,
you
> Cheers!
> Tew
> > Tew,
> Activity
(at
> least in
> > 8.03.403).
> log of
> able to
> > Good luck,
> > Aaron
On
> Behalf Of
> > Tew L. P.
> > Hi all,
> EPICOR's
> trace
> Trail
> found
> > Many thanks.
> > Tew
