Hi,
In Epicor 9.04.503B, In advanced material management module, When we are adjusting material quantity either increasing or decreasing to job through adjust material, it is not affecting in the particular job.
If we check job entry or job tracker, the material quantity is not changed after material adjustment,
Since adjust material is not working properly,Suppose if the material is issued to job greater to the required quantity how we can return the material back to inventory from job?
Thank you & Regards,
Deepa.M
Deepa.M
