No Vantage
At 08:23 AM 2/12/2001 , you wrote:
>We came into work this morning and discovered that we could not start
>Vantage from any of our workstations. The message we are getting is
>"lib/regocx.p" was not found (293). Does anyone know what may have happened?
Check on your mapped drive letter, in the directory Vantage\Lib. regocx.r
should be there. If not, try doing a find file through the whole mapped
drive to see if its's elsewhere. Is the directory writeable by users on
your lan? If so, someone could have been poking around and moved or
deleted it.
If you can post a directory listing of \Lib from your system, along with
the exact version of Vantage, someone could compare it to their's, and
possibly provide a replacement copy of the file.
You could also try reinstalling your last Vantage patch; that might replace
it. But it's probably best to find the root cause before doing that or
restoring from tape.
-Wayne Cox
Did we pick up a virus of some sort? Help!!!
Peter McGuire
Lovejoy Chaplet Corp.
pmcguire@...
(518) 686-5232
Fax: 686-4919
A couple of things to look at. (no I've never seen this alarm)
Does Procontrol show that Vantage and Vntgtrain are running?
Can you stop them and reboot the server?
IS regocx.r in x:\vantage\lib (.r is an encripted .p)
Can you compare the directory with a backup copy?
Just a few things I would check before melting completely down. :-)
RRD
could not start
are getting is
Peter McGuire
pmcguire@...
(518) 686-5232
Fax: 686-4919
Russ Dover
IS Manager
Weaver Industries, Inc.
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
Another thought
Regocx.r probably creates the regocx file in c:\vntgwork. If regocx.r
is missing are any other .r files missing?
RRD
could not start
are getting is
Peter McGuire
pmcguire@...
(518) 686-5232
Fax: 686-4919
Russ Dover
IS Manager
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
