Hi Andrew:
Sorry it took me a while to get back to you.
After reading your response and everyone elses afterwards,
I would go with what Todd Hofert said earlier.
I'm just not familiar with that error message to give you more details.
Like you said, we do the same thing where we have a bin associated
with multiple warehouses. And we have never had that error message pop up.
Sorry, I couldn't help you more.
M. Manasa Reddy
ERP Specialist
Crestview Aerospace Corporation
Email: mreddy@...
Phone: (850) 682-2746 x 272
Sent: Tuesday, January 18, 2005 9:41 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: No Whse Bin Record Available (91)
Andrew,
For each part record in the part warehouse table, you won't necessarily
find
a matching part record in the part bin table. Per Vantage, "the purpose
of
[the part warehouse table] is to indicate in which warehouses a part MAY
exist. A part CAN exist in one or more warehouses." However, the part bin
table "contains the Onhand quantity for a specific part in a specific bin
location within a warehouse. It is a subset to the PartWhse table. When
the Onhand quantity becomes zero, the PartBin record is deleted. There
should never be any records that exist with a zero quantity onhand."
Regards,
Scott
Sent: Monday, January 17, 2005 4:47 PM
Subject: [Vantage] Re: No Whse Bin Record Available (91)
Dear Manasa Reddy,
Thanks for the response.
I checked the part tracker, and it shows two warehouses, warehouse 50,
and warehouse STK. On the Bins tab, it only showed one warehouse, with
one bin location. So I ran a report. I joined the part table to
partwhse using company and part number. I then joined the part table
to partbin table using company and partnum.
What I found is that the warehousecode field in the partbin and
partwhse tables don't match (I assume this field is one of the keys,
and that they should match). Here is an example from the RB:
PartNum partwhse.WarehouseCode Partbin.WarehouseCode BinNum
15361 50 50 02N3B
15361 STK 50 02N3B
So basically the partwhese table shows that the part can exist in two
warehouses, warehouse 50 and warehouse STK. But the Partbin table only
has one warehouse for that part number. Whse 50 is the primary with a
quantity of 19. Whse STK has a quantity of zero, and cannot be deleted
because it has inventory transactions against it.
Could this be the problem? What ramifications can you see with this?
Should it be fixed? How?
Hope the info above helps.
Thanks for your help!
Andrew
M. Manasa Reddy
ERP Specialist
Email: mreddy@...
Andrew,
find
of
Regards,
Scott
Dear Manasa Reddy,
15361 50 50 02N3B
15361 STK 50 02N3B
Andrew
--- In vantage@yahoogroups.com, "Manasa Reddy" <mreddy@c...> wrote:
> did you check to see if those parts have a bin attached to them?
> M. Manasa Reddy
> ERP Specialist
> Email: mreddy@c...
> From: andrewcretors [mailto:acretors@c...]
> Sent: Monday, January 17, 2005 1:00 PM
> Subject: [Vantage] No Whse Bin Record Available (91)
> To all,
> I searched the yahoo list archive for the error above, but it didn't
> come up with anything.
> I get the error above when starting the count for inventory / cycle
> counting. Does anyone know what the error means, how serious it is,
> or how to fix it? We are on 5.1, and it came up for 5 part numbers.
> Thanks in advance!
> Andrew
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
