Non-conformance entry duplication
If you got into Quality/Inspection Processing and search for your entries you should be able to delete them from there.
Georgia
I had someone go into the MES and enter in a non-conformance to a job, however they did this entry 3 separate times. I tried to go into Time and Expense to delete 2 of the entries, however I get error messages.  Any suggestions for the best method to correct non-conformance duplications?
I’d just pass the amounts and be done with it….
Manasa
Sent: Friday, February 27, 2015 9:42 AM
Subject: [Vantage] Non-conformance entry duplication
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
If I took that action, then I would have to follow it up with quantity adjustment to remove it from inventory and a quantity adjustment increase to put all the raw material back into inventory?
What?!  Why?!
First of all do you have the quality module?
Manasa
Sent: Friday, February 27, 2015 12:10 PM
Subject: RE: [Vantage] Non-conformance entry duplication
If they did the duplication in MES on a job –  was the non-conformance done at an Operation or Job Material level?
Sent: Friday, February 27, 2015 10:10 AM
We have a BPM at Labor Update that prevent over production.
Labor Qty + Qty Completed + NonConf Qty  <= Prod Qty
If they are creating NC from the NC Entry, then a BPM on  Qty Completed + NonConf Qty  <= Prod Qty would work.
Of course if the NC is an Operation NC.
To correct what already happened, then pass the NC, Adjust what have to.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, February 27, 2015 9:40 AM
To:
