Non-Re-runable Conversion E10
#ygrps-yiv-1389332903 P.ygrps-yiv-1389332903b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1389332903 LI.ygrps-yiv-1389332903b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1389332903 DIV.ygrps-yiv-1389332903b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1389332903 TABLE.ygrps-yiv-1389332903b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1389332903 DIV.ygrps-yiv-1389332903Section1 { }
Well really you should have taken a backup, but you know that now.
Although you could manipulate the conversion table to make this re run I would not recommend it because you don't know the state the database is in nor if it works will it work next time In a continuous pass.
Without analysing the transaction scopes within the conversion your DB could easily be in an inconsistent state.
So unfortunately I would restart the process and take a backup at key milestones.
The problem is that it will probably run out of memory again. The amount of ram being used suggests that this conversion or the version you are using of it contains a memory leak.
Contact Epicor support and check if any updated versions exist.
Secondly review how much configurator input data you have that you need to keep. It may make sense to purge some especially for things like lost quotes if you have these.
Regards
Stephen
On 5 Nov 2015, at 20:36, 'Ned' TechnoBabbly@... [vantage] <vantage@yahoogroups.com> wrote:
So conversion 1320 - PCConv905
I am doing an initial migration and I did not do a backup prior to running the conversions after the migration.
This conversion is not marked as “Rerunable” and it failed due to errors:
 â€œInsufficient memory to continue the execution of the program.”
“Exception of type 'System.OutOfMemoryException' was thrown.”
Even though the server has 32GB of RAM, the w3wp.exe was using 26GB of RAM at the time when it quit.
I can’t get the conversion to run again, even tried restarting everything, are there any options that anyone knows of other than restarting the migration?
The DB is 250GB+ which is why I would really prefer to not have to completely redo the migration, especially if there is no way to know that the machine won’t run out of RAM again.
Additionally, anyone know a good way to limit the RAM usage or something else to do in a situation like this to avoid this from happening? I don’t have the ability to switch around the available RAM in the server.
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
 “Insufficient memory to continue the execution of the program.
