Good morning.
I’m hoping someone has seen this behavior before......
I created a new sheet (tab) on the Nonconformance screen called “Ticket†that fills a bunch of UD fields in the NonConf table for a subsequent report/barcode label later on.
When testing my customization on the new “Ticket†tab I created, upon entering a value in a field and tabbing out, the screen jumps back to the Material tab on the screen. If I just tab-tab-tab-tab through the fields, it all goes in the proper tab sequence on my new Ticket tab and all is seemingly well. However, if I enter any value in any of the 20 UD fields on the screen and *then* tab out, the screen flips back to the Material tab.
I customized the out-of-the-box NonConf screen, so there are no previous/hidden things going on.
Also strange, is that I used NonConf.Date01 and NonConf.Date02 to store a couple dates. I put the DateTimeEditor object on the screen like normal. When I attempt to choose a value in the editor when testing the screen, I get the “Exception has been thrown by the target of an invocation†error. In the details I see “Inner Exception: Can’t access the ‘Is Valid’ property when not in edit mode.†Huh?
Any thoughts? Thanks in advance.
Vic
Vic
