If you rename the new server with the old server's name, you can
avoid reintalling all your clients.
--- In vantage@y..., "Moore, Jim (Anniston)" <jmoore@d...> wrote:
> Terry,
> Thanks for the valuable information. I may take you up on the
phone call.
> My main concern now is not messing up the live database on the NT4
box while
> trying to get the W2K server going.
> Thanks.
> Jim
> -----Original Message-----
> From: Terry Williams [mailto:tlw@m...]
> Sent: Wednesday, August 21, 2002 11:38 PM
> To: vantage@y...
> Subject: RE: [Vantage] NT4.0 Server to W2K
> Jim:
> Amazing one can proofread and still not catch something. As I
read this
> after the posting, I realized by doing steps 10 and 11 (repeating
the
> probackup and prorestore and then starting the database) you're
gonna have
> an older database with newer patches. It won't work. Don't apply
the
> latest patches to W2K until you're satisfied the install is ok and
you're
> ready to shut off the NT4 machine. Then you'll want the most
current
> database on W2K and that's from where you'll start. So, ignore
the previous
> list of steps and see below as I've redone the order.
> Now's the perfect time to gain some valuable experience.
> 1. Install the W2K server as a member server
> 2. Using the original Progress/Vantage cd, go
through the
> install in W2K.
> 3. Apply the patches to get you current to where
you are
> now on NT4.
> 4. Do an online probackup of the database from
the NT4
> machine
> 5. Do a prorestore to the W2K machine
> 6. At this point, you should have a duplicate of
NT4 on
> the W2K machine
> 7. Start/stop/start the database, connect a
client or two
> or three
> 8. Once you've satisfied yourself all is ok,
repeat steps
> 4 and 5 (since a day or two will probably have passed by now)
> 9. Repeat step 7
> 10. Apply the latest and
greatest patches
> to both Progress and Vantage
> 11. Repeat step 7
> 12. Uninstall Progress on the
clients
> 13. Disconnect the clients from the
NT4 server
> 14. Connect the clients to the W2K
server
> 15. Install Progress/Vantage on the
clients
> After all this and you still are confused - easily done - call.
> Terry L. Williams 176 Shadywood Circle Cranberry,
PA 16319
> ph/fax: 814-676-8650 tlw@m... <mailto:tlw@m...>
> From: Moore, Jim (Anniston) [mailto:jmoore@d...]
> Sent: Wednesday, August 21, 2002 11:23 AM
> To: 'vantage@y...'
> Subject: [Vantage] NT4.0 Server to W2K
> I am replacing our Vantage NT4.0 server with a W2K server.
> Can someone please provide me with a "checklist", detailed
instructions are
> even better, of items to do.
> We are on 4.00811 and 9.0B29.
> We do NOT plan on upgrading to 5.x because of corporate mandates.
(We will
> use their system in about a year).
> Tech support did recommend upgrading the Progress patch to 9.0B44.
> Can I go from Progress and Vantage right off the CD's to .811 and
9.0B44,
> skipping patches in between?
> Will installing another installation of Vantage on our Lan cause
problems
> with the live version?
> Any help and advice is appreciated as I have never attempted this
before.
> Thanks.
> Jim Moore
> jmoore@d...
must have
Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> < http://docs.yahoo.com/info/terms/> .
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://rd.yahoo.com/M=228862.2128520.3581629.2204139/D=egroupweb/S=1
7050071
> 83:HM/A=1182733/R=0/*http://adfarm.mediaplex.com/ad/ck/990-1736-
1039-334%0D%
> 0A>
must have
Builder and
> <http://docs.yahoo.com/info/terms/> .
must have
Builder and
