Number of Occurrences - BAQ
Hello,
Does anyone know how/if to do the following in a BAQ?
select
	ABCCode.CountFreq,
	COUNT(ABCCode.countfreq) as NumOcurr
from ERP.ABCCode
group by (ABCCode.CountFreq)
When I try recreating it in a BAQ I can an error;
Severity: Error, Table: , Field: , RowID: , Text: Column ‘Erp.ABCCode.CountFreq’ is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
Post Withdrawn - it was not relevant to the quetsion
Not quite the same thing. Trying to count the number of occurrences of the some countfreq. ABCCode is silly example, but I was trying to make it simple.
So I have 2 ABCCodes that have 33 as the countfreq.
You mean like this?
VERY simple:
  1. Display CountFreq field - MARK AS GROUP BY <—This is the magic!
  2. calculated field called NumOccur = Count(ABCCode.ABCCode)
    Here is the resulting BAQ Query phrase:
Thanks @timshuwy! Turns out I had the table set as a Summary table. Which I assumed I needed because I was using an aggregate function.
