>BTW, what version are you running?We're running 9.04.507
>How is the quantity called out on the BOM now?Unfortunately we use component quantity at the moment.
>Reel qty or component qty?
Could be an idea to look into using the reel quantity instead
Thanks for the help
Mark Taylor
Senior Document Controller
Hansatech EMS provides value manufacturing through engineering and
quality
Hansatech EMS Limited
Benson Road
Nuffield Industrial Estate
Poole
Dorset BH17 0RY
United Kingdom
Tel:
Fax:
DDI:
+44 (0)1202 338200
+44 (0)1202 338202
+44 (0)1202 338228
Mark.Taylor@...
www.HansatechEMS.com
Of cooner_55421
Sent: 20 June 2011 17:08
Subject: [Vantage] Re: Number of Reels per BoM
> two heads on the machine to speed things up,OK thanks, there is nothing I have tried before.
If it's a straight reel qty maybe two operations on the job, each
calling out for it's own reel?
If it's the component qty that is called out on the BOMs, wow.
A wild guess, maybe a resource setup?
"Mark Taylor" <mark.taylor@...> wrote:
>reels
> Part reels are not a problem for us as we can use them, as this is
> of surface mount components.minimum
> What we are trying to do is optimise the machine programs, so for
> example if we need to fit a lot of capacitors to a board we could use
> two heads on the machine to speed things up, and so would need a
> of two reels.[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Mark Taylor
> quality
> Benson Road
> Poole
> Dorset BH17 0RY
> United Kingdom
> Tel:
> Fax:
> DDI:
> +44 (0)1202 338200
> +44 (0)1202 338202
> +44 (0)1202 338228
> Mark.Taylor@...
Behalf
> Of cooner_55421<mailto:vantage%40yahoogroups.com> ,
> Sent: 20 June 2011 16:12
> >the minimum number of reels to but for a part?
> I use Min Order Qty to accomplish something like this.
> Min/Max/Re-Order to Max but they only get me so far.
> I'm curious, do you end up with partial reels & is it a problem?
> We have a problem like this:
> Two left over 20" long pieces of raw material, (inventory says 40")
> can't make one 30" finished piece.
> Raw material has to be at least 30" long to make the part.
> And you can't always scrap the 20" long raw material peices because
> there are other shorter finished parts that can be made from them.
> I have not found a way to use the system & handle these manually.
> "Mark" <mark.taylor@> wrote:______________________________________________________________________
> > Hi All,
> > Does anyone know of a way for Epicor to show the minimum number of
> > We are an electronics manufacturer and we use machines to place our
> components. What we would like to do is to specify the number of reels
> that a part is to have on a BoM so that we can optimise some of the
> machine programs.
> This email has been scanned by the MessageLabs Email
