O.T (Dual boot)
>>Ok, one of my home computers (test PC) has just this set up. Only I added
a
third drive and stuck WIN2K Server on that to play with as well.
Disclaimer: "Play with" = Evaluate the newly purchased software before
removing it and installing it on a "work computer". (The reason I like
doing this all on separate drives is a "clean" removal from the system is
easy and practical)
Thank you unnamed party...
Aaron
I am trying to setup a dual boot on my client. Orginal Disk 1 Windows 98
fat32. I installed Disk 2 formatted it as fat32 and loaded XP on it. The
setup process created this new drive as my system drive and labeled it as
the C drive. Disk 1 was then relabeled as the D drive. The default OS is XP.
When I start the machine and select Windows 98 from the OS selection screen
I get an error messages indicating that it cannot locate 98 startup files on
my C drive. I am fairly certain it's a matter of changing the boot.ini file
but I am uncertain what to change. Any help would be greatly appreciated.
Dan Shallbetter
States Electric Mfg.
Dan,
In the past I found some good help for Dual boot situations from the Microsoft website. There is a newsgroup you can monitor there to answer very specific questions, and there is a Qbase article about step-by-step to do's for dual booting. I suspect (I'm guessing now), you may need to reinstall Win98 with your current configuration using the D: drive as the install drive for Win98. Then you (I forget the right word for this), reinstall XP and do a "repair install" or something like that, which would simply reconfigure the dual-boot with Win98 again. Here are some articles you might reference.
http://support.microsoft.com/newsgroups/default.aspx
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q217210\
http://support.microsoft.com/default.aspx?scid=kb;en-us;q306559
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q153762
http://www.microsoft.com/windowsxp/pro/using/howto/gettingstarted/multiboot.asp
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, June 25, 2002 5:43 AM
Subject: [Vantage] O.T (Dual boot)
Dan Shallbetter
Dan:
http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q306559&LN=EN
-US&rnk=1&SD=tech&FR=0&qry=dual%20boot%20windows%2098&src=DHCS_MSPSS_tech_SR
CH&SPR=WINXP&
<http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q306559&LN=E
N-US&rnk=1&SD=tech&FR=0&qry=dual%20boot%20windows%2098&src=DHCS_MSPSS_tech_S
RCH&SPR=WINXP&>
Check this out. Pretty self-explanatory here.
Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St. Ext.
Meadville, PA 16335
p.814-333-6331 x236 f.814-337-2548 c.814-671-8650 tlw@...
<mailto:tlw@...> www.chipsco.com <http://www.chipsco.com/>
Sent: Tuesday, June 25, 2002 8:44 AM
Dan Shallbetter
Terry thanks for the reply.All the articles I've seen on the dual boot issue
talk about using a single drive with multiple volumes (partitions) and
installing each O.S on it's own partition. I have installed each O.S on it's
own drive. The windows XP drive being the System drive, the windows 98 drive
is shown as an active drive. I suspect it needs to be either a boot drive or
a system drive and I believe your limited to one of each per system. I was
told at Best Buy that what I am trying to do is possible, but all the
tech-net articles I've read seem to suggest otherwise. I was hoping someone
had already blazed this trail.
Dan Shallbetter
Sent: Tuesday, June 25, 2002 1:33 PM
Subject: RE: [Vantage] O.T (Dual boot)
Dan:
N> &LN=EN
CH&SPR=WINXP&
< http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q306559
> &LN=E
RCH&SPR=WINXP&>
Meadville, PA 16335
<mailto:tlw@...> www.chipsco.com < http://www.chipsco.com/
<http://www.chipsco.com/> >
Dan Shallbetter
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.2150041.3600347.1829184/D=egroupweb/S=17050071
83:HM/A=979988/R=0/*http://www.fastweb.com/ib/yahoo-79f>
<http://us.adserver.yahoo.com/l?M=178320.2150041.3600347.1829184/D=egroupmai
l/S=1705007183:HM/A=979988/rand=108226833>
Dan:
In the boot.ini file you specify which drive holds which OS right down to
the partition of each physical drive. I have a drive with DOS/Win98/W2K. I
'll get it out and fire it up, copy the boot.ini and send it to you. Fair
enough?
Meadville, PA 16335
Sent: Tuesday, June 25, 2002 2:59 PM
To: 'vantage@yahoogroups.com'
Dan Shallbetter
Dan:
N> &LN=EN
CH&SPR=WINXP&
> &LN=E
RCH&SPR=WINXP&>
Meadville, PA 16335
< http://www.chipsco.com/> >
Dan Shallbetter
< http://groups.yahoo.com/group/vantage/files/.>
< http://groups.yahoo.com/group/vantage/messages>
< http://groups.yahoo.com/group/vantage/links>
< http://docs.yahoo.com/info/terms/ < http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
83:HM/A=979988/R=0/* http://www.fastweb.com/ib/yahoo-79f>
< http://docs.yahoo.com/info/terms/> .
>> I was hoping someone had already blazed this trail.
Ok, one of my home computers (test PC) has just this set up. Only I added a
third drive and stuck WIN2K Server on that to play with as well. There are
a bunch of places that things could have gone wrong during the installation,
but the method that I have found most effective is to have 98 working, and
then install the extra drive. Do not Fdisk or format it at that time.
Restart the computer to verify that 98 is still functioning (you don't have
a master/slave issue). Then I boot from the XP CD and install it choosing
to install on the empty drive. Personally I like to format the new drive as
NTFS so 98 can't see it anyway. After installing it should then reboot and
ask for the version of windows and both should work. I have run into the
problem once with XP calling it's drive C: even though it should be D: (a
little trick that NT based systems can pull but not 98 systems), but I think
I resolved it by dumping the XP drive and starting it over.
Multi-boot will work with most any Windows OS, so long as the first on is
the 98/95 os and everything added after is of the NT base (NT/2000/XP). The
only snag that I have not made it past is trying to get 98 and ME on the
same system...But then again I only wanted ME to see if it could be done.
If you want any further pointers, feel free to contact me on or off list.
Aaron Hoyt
Information Systems Manager
Design Standards Corp.
PO Box 1620
Charlestown, NH 03603
Tel 603-826-7744
<mailto:aaron.hoyt@...>
(Practice Save Computing, get a free online virus scan at:
http://housecall.antivirus.com/)
Sent: Tuesday, June 25, 2002 3:00 PM
Aaron.
I followed the same procedure that you outlined. I had to manually edit the
boot.ini file I copied the line referencing the XP location but changed
rdisk(0) to rdisk(1) for the disk containing Win98. I now get the following
error when trying to launch Windows 98: Windows could not start because the
following file is missing or corrupt Windows root\system32\hal.dll.
Microsoft K.B Q320252 comes close to describing the problem. I am able to
run XP (the default O.S) without problem. I ran the bootcfg \rebuild from
the XP recovery console in an effort to fix the 98 problem but to no avail.
How did you dump the XP drive? Uninstall or reformat?
Dan Shallbetter
Sent: Wednesday, June 26, 2002 9:52 AM
Aaron Hoyt
PO Box 1620
Tel 603-826-7744
http://housecall.antivirus.com/) <http://housecall.antivirus.com/)>
Dan,
I removed the drive and made sure 98 was on c: (rdisk(0)). 98 Should start
to work with a little playing after the other drive is out. If you took the
path I did last time, you might want to try formatting the second drive from
98 as the D: drive and then install XP to that drive with "no change to the
current file system". That might do the trick on this machine.
Are they both reasonably fresh installs that you don't mind reinstalling???
It might be faster if you can to just wipe both drives clean and install 98
on the one, then set up the other and install XP on it.
Just another thought.
Aaron
Sent: Wednesday, June 26, 2002 11:17 AM
Aaron.
Dan Shallbetter
Aaron Hoyt
PO Box 1620
Tel 603-826-7744
