I have to agree with Toby on setting up a separate network for visitor
access.
I have gone to the trouble to wire some Cat5 jacks (color coded) to the
"customer" network and added a cheap wireless AP for customers. This is
routed through an extra Cisco router. This router is set up on a
separate extra external IP provided by our ISP (we needed 2 and got a
block of 5). This provides visitors a wireless or wired connection that
is totally separate from our network yet with a reasonable firewall for
their security. It also has the added benefit of acting as a decoy for
any one savvy enough to attempt to hack our wireless. It's ID is not
hidden like our internal wireless network and has less security to make
it a more attractive target. It's the the old trick of watch my left
hand while my right hand works the magic.
It was not that expensive to set up, and I consider all the parts
involved my "backup" parts for our internal network (I can live without
visitor access for a few days while replacement parts are on the way,
but I don't want my internal network down while I wait for a new router
or AP).
Best of luck,
Aaron Hoyt
Vantage Plastics
Toby Boogerd wrote:
access.
or AP).
Best of luck,
Aaron Hoyt
Vantage Plastics
Toby Boogerd wrote:
>[Non-text portions of this message have been removed]
> Your better option is to put the visitors on a separate network and
> route that network through your firewall to allow internet traffic. Even
> if you have to buy a separate wireless router to do this. Just set it up
> with a difference IP base than your internal network and route it
> through your firewall.
> Other options include using demilitarized zones and/or VLANs on specific
> ports if hard wiring. Many options depend on your specific setups and
> hardware.
> From: Todd Caughey [mailto:caugheyt@...
> <mailto:caugheyt%40harveyvogel.com>]
> Sent: Monday, September 22, 2008 8:24 AM
> Subject: RE: [Vantage] O.T. - Wireless LAN
> We do this here in a limited fashion. We can a access our network via a
> wireless router/switch (although the prefered method for the laptop
> people is wired....much faster) and also provide web access for
> visitors. To login to our network requires our domain name otherwise the
> network validaiton part fails and it establishes a local login that
> still gives them web access. Most visitors have their home domain name
> in their login so when this fails they get a local login to their
> laptop. But the DHCP server still gives them IP addresses (including
> gateway) and DNS service through the firewall. All this assumes casual
> usage by visitors and not trying to protect from malicious access
> attempts to our network resources. I think the wireless router also does
> some isolation because without logging in to our network all they can
> see in terms of other PCs are the ones linked to the wireless router.
> This was by default right out of the box with a $40 D-Link wireless
> router. I should probably setup WAP security but we are in an isolated
> location too far from roads for the signal to be used outside the
> building so I have never bothered with it.
> -Todd C.
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of randyduly
> Sent: Sunday, September 21, 2008 4:53 PM
> Subject: [Vantage] O.T. - Wireless LAN
> I am wandering what other people have done. I have a network with some
> HP Switches in my wiring closet. I want to set up a wireless LAN for
> our internal Laptop users and also be able to let customer's access
> the Internet with their laptop for access to their email or to connect
> to their office. But also to keep the customer from accessing our
> internal network.
> I don't want to spend megabuck either. What have other done. Thanks in
> advance.
