You seem to be modifying the control and not the data view.
try
(This is C# syntax I don't know VB)
EpiDataView soDV = (EpiDataView)oTrans.EpiDataViews["OrderRel"];
case 0:
soDB.dataView[soDB.Row]["CheckBox01"]=false;
soDB.Notify("NAMEOFYOURFORM",soDB.Row,soDB.Column);
case 1:
soDB.dataView[soDB.Row]["CheckBox01"]=true;
Sincerely
Jose C Gomez
http://www.josecgomez.com
try
case 0:
case 1:
Sincerely
Jose C Gomez
On Thu, Jul 22, 2010 at 3:51 PM, Nathan <bonner.n@...> wrote:
> I have the following code on OrderRel as part of our Drop Ship integration
> (tying a PO to a Sales Order without a Job). The trouble is that the Object
> Properties aren't changing as expected. Any suggestions?
> Private Sub OrderHedList_DataView_ListChanged(ByVal sender As Object, ByVal
> args As ListChangedEventArgs) Handles OrderHedList_DataView.ListChanged
> '// ** Argument Properties and Uses **
> '// args.CurrentView.dataView(args.CurrentRow)("[FieldName]")
> '// args.LastRow, args.CurrentRow, args.CurrentView
> 'Add Event Handler Code
> Dim PONum as Integer
> PONum = nedEpiCustom5.value
> Select Case PONum
> Case 0
> chkEpiCustom2.ReadOnly = FALSE
> Case Else
> chkEpiCustom2.ReadOnly = TRUE
> End Select
> End Sub
> Thanks,
> Nathan Bonner
