ODBC (again)
Hey Guys:
I've seen this before and (if I remember correctly) the fix for this
problem is to upgrade the Jet version on your workstation where
you're running MS Access.
Go to this URL and download Jet 4.0:
http://support.microsoft.com/support/kb/articles/Q239/1/14.ASP
At the bottom of that page they have "#Deleted in Linked Table
Containing UniqueIdentifier" under the issues resolved section. I
think this will fix ya' up.
D. Smith
--- In vantage@y..., Brian Davis <bdavis@w...> wrote:
> Thanks for the response. At least I know I'm not alone. Now I
just have to
> figure out how to deal with it...B
> -----Original Message-----
> From: Gitzlaff, Christopher [mailto:cgitzlaff@m...]
> Sent: Wednesday, December 20, 2000 9:43 AM
> To: 'vantage@egroups.com'
> Subject: RE: [Vantage] ODBC (again)
> Brian,
> I've had the same problems with Access. I was working on the
report for the
> 1099's and wanted to use the primary vendor contact. In the
Vendcnt table,
> half of the records show up as #Deleted, just like yours. I was
told by
> Vantage support that this is a problem between Access and
Progress. The
> only workaround I've found is an export to Excel, then an import
into MS
> Access. Unfortunately, the report results were not correct until I
did the
> export/import routine on the Vendcnt table.
> I feel your pain.
> Christopher Gitzlaff
> Manager - Information Systems & Technology
> Major Industries, Inc.
> From: Brian Davis [mailto:bdavis@w...]
> Sent: Wednesday, December 20, 2000 10:30 AM
> Subject: [Vantage] ODBC (again)
> Has anyone tried to use JOBPROD in an MS Access program? I have
written
> some programs, reports, and queries, using the latest Merant driver.
> Mostly, they work fine, with the exception of the errors we talked
about a
> few months ago. However, yesterday I tried to use the JOBPROD
table for the
> first time. The data does not display. In all fields of all
records, the
> data displays as "#Deleted". I can use it in queries, and the
criteria I
> enter against JOBPROD results in the correct records. I can tell
this
> because the data from other linked tables in the query show up
correctly.
> Only the fields from JOBPROD display wrong.
> Any response would be greatly appreciated...B
> We no longer allow attachments to files. To access/share Report
Files,
> please go to the following link:
http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try
it, go to
> www.egroups.com, login and be sure to save your password, choose My
Groups,
> choose Vantage, then choose Files. If you save the password, the
link above
> will work the next time you try it.)
Files,
it, go to
Groups,
link above
Has anyone tried to use JOBPROD in an MS Access program? I have written
Mostly, they work fine, with the exception of the errors we talked about a
few months ago. However, yesterday I tried to use the JOBPROD table for the
first time. The data does not display. In all fields of all records, the
data displays as "#Deleted". I can use it in queries, and the criteria I
enter against JOBPROD results in the correct records. I can tell this
because the data from other linked tables in the query show up correctly.
Brian,
I've had the same problems with Access. I was working on the report for the
1099's and wanted to use the primary vendor contact. In the Vendcnt table,
half of the records show up as #Deleted, just like yours. I was told by
Vantage support that this is a problem between Access and Progress. The
only workaround I've found is an export to Excel, then an import into MS
Access. Unfortunately, the report results were not correct until I did the
I feel your pain.
Thanks for the response. At least I know I'm not alone. Now I just have to
Brian,
I feel your pain.
