Kill.exe did the trick. Thanks.
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, April 17, 2001 4:31 PM
Subject: RE: [Vantage] ODBC clogging server
> Troy,
> Do you have the NT resource kit? Look for a utility called KILL.EXE. You
have to have the PID (Process ID) from Task Manager, then enter "kill pid".
If you don't have the Resource Kit, send me an e-mail...
> Matt
> -----Original Message-----
> From: Troy Funte [mailto:tfunte@...]
> Sent: Tuesday, April 17, 2001 3:03 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] ODBC clogging server
> This is not a vantage user instance. The Crystal report was started
outside of Vantage and doesn't show up in Promont.
> It is a system process in NT called oidrvr32.exe.
> Troy
> From: Jerry Solobay
> Sent: Tuesday, April 17, 2001 3:49 PM
> Kill them with the Vantage Monitor option 8 then look for the System
process
> that has a start date that matches.
> Best regards,
> Jerry Solobay
> IS/IT Manager
> Ebco Aerospace
> Sent: Tuesday, April 17, 2001 12:47 PM
> Subject: [Vantage] ODBC clogging server
> NT guru's.... Our Dual-450 server is pegged at 100% CPU usage. The
culprits
> are two instances of , which were started when Crystal access
> ODBC. Both of the reports that started the oidrvr32.exe have been shut off
> (they didn't progress after four hours). but the processes for
oidrvr32.exe
> keep chugging along hogging 45 to 50% of the CPU each.
> Clicking End Task on the server (in Task Manager) doesn't kill them off
> because of an "Access is Denied" error. (I'm logged on as Administrator).
> Besides restarting the server, does anyone know of a way to stop this
beast
> (oidrvr32.exe)?
> Troy Funte
> Liberty Electronics
> To access the Files Section of our Yahoo!Group for Report Builder and
> Crystal Reports and other 'goodies', please go to:
> http://groups.yahoo.com/group/vantage/files/. Note: You must have already
> linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Yahoo! Groups Sponsor
> Click Here to Find Software Faster
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
