ODBC connection (Access)
Assuming you have the ODBC user setup in Progress, go to Control Panel
--> Admin Tools --> Data Sources (ODBC) --> System DSN tab, click "Add".
Data Source Name: MFGSYS61
Description: MFGSYS61 (or whatever you want)
Host Name: servername
Port Number: 6150 (for the main DB)
Database Name: mfgsys
User ID: sysprogress (or odbcuser or whatever you have setup for your
Progress user name)
Be sure to go to the "Advanced" tab and select "READ UNCOMMITTED" and I
believe someone mentioned changing the Fetch Array to 2000.
Epicor support has a nice ODBC setup documentation available if you have
that option.
Of Chris Crosta
Sent: Wednesday, November 15, 2006 2:10 PM
Subject: RE: [Vantage] ODBC connection (Access)
I have tried to connect through "External Data" but when I select the
ODBC connection Access closes the screen. I think there is something
that needs to be set in the data sources either file or system DSN. I
have the Merant drivers installed and configured for Crystal and
everything works fine.
Chris
_____
Behalf
Of sarah.vareschi@... <mailto:sarah.vareschi%40nypromold.com>
Sent: Wednesday, November 15, 2006 11:00 AM
To link to the vantage data and assuming ODBC is already set-up:
Within Access db go to 'File' -> 'Get External Data' -> 'Link Tables'
The browse will open -> at the bottom under 'files of type' -> change
this to "ODBC databases" -> then your ODBC data sources will open and
you select the one you created for vantage.
Behalf
Of Chris Crosta
Sent: Wednesday, November 15, 2006 1:51 PM
Subject: [Vantage] ODBC connection (Access)
How do I make an ODBC connection to Vantage through Access? I did this
a couple of months ago on a test machine and can't remember the
connection procedure.
Vantage 6.1.533
Access 2003
TIA
Chris
<http://groups.yahoo.com/group/vantage/files/> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
Yahoo! Groups Links
Vantage 6.1.533
Access 2003
TIA
Chris
Of Chris Crosta
Vantage 6.1.533
Access 2003
TIA
Chris
Yahoo! Groups Links
Chris
_____
Behalf
Of Chris Crosta
Vantage 6.1.533
Access 2003
TIA
Chris
Yahoo! Groups Links
You can create a macro that links to Vantage, extract with query (or if
you dare - update Vantage), clear the link and work with the data
extracted. Here is the macro:
Setwarnings = off to avoid messages
Transfer Database = Within this option:
TransferType = Import or Link
DatabaseType = ODBC
DatabaseName = ODBC;DSN=mfgsys61;HOST=[Server Name];PORT=[ODBC
Port];DB=vantage;UID=sysprogress;PWD=[your odbc password]
ObjectType = Table
Source = PUB.part
Destination = PUB_part
StructureOnly = Yes - no data No - includes data.
With these options, you are importing or linking the Part table.
OpenQuery - to extract data from the table to another table, etc.
DeleteObject = PUB_part to clean the link-import.
msgbox = Complete! Click OK.
Setwarnings = on
You can associate this macro with a button and your final user does not
need to enter passwords, etc. - just click the button to extract and
work with Vantage data. I have done a lot of neat databases even to
modify data in Vantage (using committed). This works with Access 2002.
Good luck!
Mario E. Aguirre - IT Manager
Lakin General Corporation, Inc.
Of Chris Crosta
Sent: Wednesday, November 15, 2006 12:51 PM
Vantage 6.1.533
Access 2003
TIA
Chris
