Hi,
I too was struggling with the #deleted return from tables I really needed to access (no pun). An alternative method is to create a new project in Access. This immediately launches a wizard askiing if you need to connect to an existing SQL database. Add the details & you have a database with all the Vantage tables added. You are able to create queries (now called views) in much the same way (but not 100%) and retain the Access ease of integration with other Office products.
--- In vantage@yahoogroups.com, "rocket7247" <joan.d.sweeny@...> wrote:
> I have created a ODBC DSN to connect to the live database via. MS ACCESS with version Epicor9.05602A. When I open a table, I get a table of all "#deleted" columns. Has anyone had success in connecting tables ODBC using this version of Epicor 9?
> Thank you for your assistance.
