ODBC Connection - Trusted Vs Not Trusted
Vic wrote:
> Trusted means that the domain login has a domain login on SQL Server.
> "untrusted" means that you've set up a generic login on your
> SQL server.
> The benefit of trusted is the user isn't prompted for a user
> name and password every time they use ODBC. The drawback is
> that if you have a lot of ODBC users it can be a PITA to set
> up all the privileges for each user.
For my SQL work, I ONLY use trusted connections. I manage multiple users by
putting them into AD Security Groups. One group for read-only, another for
power-users, an admin group (for full access), etc. Now I just have to add
users to security groups. If a user leaves the company, I don't worry as
long as the user account is disabled. Also, there's no hard-coding passwords
into your code.
It's the only way to go IMHO.
Mark W.
What is the difference between having an ODBC connection setup as trusted Vs. Untrusted? What are the benefits of each? Disadvantages?
Â
Dustin Biniek
Simple:
"untrusted" means that you've set up a generic login on your SQL server.
The benefit of trusted is the user isn't prompted for a user name and password every time they use ODBC. The drawback is that if you have a lot of ODBC users it can be a PITA to set up all the privileges for each user.
I have a generic login that provides READ ONLY access. For some users who love Excel and need to download the contents of a table I provide them the untrusted login info.
We have CSG's ADP Payroll custom code and for my 2 Payroll clerks I've set up as TRUSTED because they use it all the time and a login would be a PITA and also they require UPDATE/DELETE/INSERT access privileges to the ADP supplementary tables.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Sent: Thursday, October 08, 2009 3:48 PM
Subject: [Vantage] ODBC Connection - Trusted Vs Not Trusted
Â
Dustin Biniek
