ODBC error (-7748) using Access 2007 on Vista 64bit
When trying to use Microsoft Access 2007 and the OpenEdge 10.1b ODBC
drive on a Vista 64bit system I was getting the error "Reserved error
(-7748): there is no message for this error".
To fix this, open the registry and add the following fix.
Run RegEdit
2. Locate the ODBC DSN in the Registry:
For a SYSTEM Data Source, go to HKEY_LOCAL_MACHINE -> Software ->
Wow6432Node -> ODBC -> ODBC.INI -> YourDataSourceName
3. Click on the folder for your data source; from the menu choose:
Edit -> New -> String Value
4. Set the name of the new string value to be WorkArounds2
5. Double click on WorkArounds2 in the right hand panel; this will
bring up a dialog box with a data value field
6. Change the data value to WorkArounds2=40960
7. Click OK
8. Close RegEdit
After doing this I can now use the ODBC drive on my 64bit Vista and
Access 2007.
Hope this helps,
Dave Olender dolender@...
Ph: 651-246-3281
