ODBC: LEFT OUTER JOIN were not found in an outer join escape seq
That sounds identical to the problem we have, and this is the registry
fix we use for it:
a. Open the registry.
b. Navigate to the following key;
--> HKEY_CURRENT_USER\Software\Seagate Software\Crystal
Reports\DatabaseOptions\OuterJoin
c. Select the following subkey; --> openingres
d. Right click on subkey, select "modify".
e. Add "pgpro915" to the existing values, eg. Oplodbc, oplodb32,
pgpro915
Brian.
Of Todd Gilbert
Sent: Tuesday, October 26, 2010 1:24 PM
Subject: [Vantage] ODBC: LEFT OUTER JOIN were not found in an outer join
escape sequence
Trying to run a Crystal Report with an outer join between tables and get
the error message "ODBC error:[MERANT][ODBC SQLBase driver]The keywords
LEFT OUTER JOIN were not found in an outer join escape sequence." We're
using Merant driver 3.60 on Vantage 6.1.
Any ideas?
Thanks in advance!
Todd Gilbert
GCM, Inc.
Any ideas?
Thanks in advance!
Todd Gilbert
GCM, Inc.
