ODBC/OLE DB connections with Crystal Reports and Epicor
Hi Lin: We are on 8.03.408 and have been using ODBC with crystal since 2003 with 6.1. We use this for complicated reporting that we can't do using BAQ's.
I would be interested in your experiences as to why ODBC shouldn't be used with Crystal reports.
Virginia Joseph
Deep Hole Specialists
440-543-8157
440-543-4882 Fax
--- In vantage@yahoogroups.com, Lin <plmidnightpassage@...> wrote:
> By the way, you are not suppose to use ODBC via Crystal Reports
> Peace and tranquility,
> Lin
> --- On Tue, 3/2/10, wsnowfl <wbsnow@...> wrote:
> From: wsnowfl <wbsnow@...>
> Subject: [Vantage] ODBC/OLE DB connections with Crystal Reports and Epicor
> To: vantage@yahoogroups.com
> Date: Tuesday, March 2, 2010, 2:42 PM
> I am trying to do some reports that are complex so require ODBC â€" must use stored Procedures can't do it in BAQ. I am connecting using OLE DB for SQL Server. I can connect and run the reports fine from Vantage menu, but when other users do, the program exits after they click the print report or print preview icon.
> using Microsoft SQL Server
> OLE DB connection to database
> Using sysprogress
> Sysprogress has rights to the database
> Run from Vantage menu as Custom Report Link
> Any ideas? Is there a "standard" way to do this? I have never had to before being relatively new to vantage but not to report writing. It would seem that for complex reports most every Vantage customer would eventually need to use ODBC or OLE DB? But I cannot find any documentation from Epicor besides BAQ Reports. Help desk has been no help.
> Any ideas?
I am trying to do some reports that are complex so require ODBC – must use stored Procedures can't do it in BAQ. I am connecting using OLE DB for SQL Server. I can connect and run the reports fine from Vantage menu, but when other users do, the program exits after they click the print report or print preview icon.
Using sysprogress
Any ideas?
Have you got the Crystal Reports 2008 Reader on the client PC's?
Tim Dines
Information Technology
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
Direct: 765-675-5201
Cell: 765-437-1402
Of wsnowfl
Sent: Tuesday, March 02, 2010 2:43 PM
Epicor
I am trying to do some reports that are complex so require ODBC - must
Using sysprogress
help.
Any ideas?
Hi,
I had the same thing just last week.
Do the other users have the DSN with the proper drivers installed?
Sebastien.-
> Tim Dines
> 801 Berryman Pike
> Tipton, IN 46072
> Cell: 765-437-1402
> Of wsnowfl
> Epicor
> Using sysprogress
> help.
> Any ideas?
Never mind. I found the reason for the problem. I was using the mapped drive letter rather than UNC path name for the rpt file. Used UNC (or if we had a standard drive mapping convention) and it worked.
> Using sysprogress
> Any ideas?
Have you set them up with ODBC connection on their computer as well?
Lin
Â
Using sysprogress
Any ideas?
By the way, you are not suppose to use ODBC via Crystal ReportsÂ
Lin
Â
Using sysprogress
Any ideas?
Why are you not supposed to use ODBC connections with Crystal Reports?
I have been using this for many years.
Jerry Rodden
SA - Production Planning/MRP
Cardington Yutaka Technologies Inc.
575 West Main Street
Cardington, OH 43315
Phone: 419-864-8777 ext. 6209
Fax: 419-864-7771
Email jrodden@...
