Not that I know of. I think you can only do this at initial link.
> When you choose what tables to link in Access there is a checkboxin the
> lower left corner that says "Remember Password". Put a check thereand that
> will do the trick.when
> Good luck,
> Jeremy Leonard
> IT Manager
> K-T Corporation
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Thursday, July 17, 2003 8:38 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] ODBC Password
> Does anyone have a way of avoid the prompt for the ODBC password
> using ODBC in Access? I know you can use a file DSN and includethe
> password in the dsn which helps with Crystal Reports and with thereappears.
> initial creation of a linked table in Access, but after that, when
> you try to access the info in the table the password prompt
>must have
> I'm working on a test implementation for 5.2 with ODBC SQL 92 and
> Access 2002. Any ideas will be greatly appreciated.
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
> already linked your email address to a yahoo id to enable access. )Builder and
> Crystal Reports and other 'goodies', please goto:http://docs.yahoo.com/info/terms/
> Your use of Yahoo! Groups is subject to
> Good luck,
> Jeremy Leonard
> IT Manager
> K-T Corporation
>must have
> Thanks,
> Brian Stenglein
> Clow Stamping Co.
