ODBC Performance
One more time: Not all of the spacing worked out right on the code snippet
(don't want to mess anybody up) :)
Code Snippet
'***** Connect To Progress Database (Vantage)
strConnect = "DSN=ProgressRC;UID=sysprogress;PWD=sysprogress;"
Set dbsVantage = Server.CreateObject("ADODB.Connection")
dbsVantage.Open strConnect
dbsVantage.Execute "SET SCHEMA 'PUB'"
Dim arrOrder
Set rstOrder = Server.CreateObject("ADODB.Recordset")
strSQL = "Select OrderNum, NeedByDate FROM OrderHed WHERE OpenOrder <> 0"
rstOrder.Open strSQL, dbsVantage
arrOrder = rstOrder.GetRows
rstOrder.Close
dbsVantage.Close
Response.Write "<html>" & vbCrLf
Response.Write "<head><title>Sample</title></head>" & vbCrLf
Response.Write "<body>" & vbCrLf
Response.Write "Order, Need By Date<br />" & vbCrLf
Dim i
For i = 0 To UBound(arrOrder, 2)
Response.Write arrOrder(0, i) & ", " & arrOrder(1, i) & "<br />" & vbCrLf
Next
Response.Write "</body>" & vbCrLf
Response.Write "</html>" & vbCrLf
End Code Snippet
Sent: Thursday, March 17, 2005 3:10 AM
Subject: RE: [Vantage] ODBC Performance
Christopher,
How do you have your server set up to do your web based
reporting I would love to do this on our intranet. Shirley Graver Rubber
Associates
_____
Sent: Wednesday, March 16, 2005 5:12 PM
Subject: [Vantage] ODBC Performance
I was working on a report for our internal company website (Intranet) and
ran across an interesting performance issue. On occasion, we use Report
Builder to generate the SQL statement for our Intranet pages. We create a
basic report in Report Builder, press "<ctl><alt>P", then press "F12". This
will give the SQL statement being used by Report Builder.
Running the base report in Report Builder took less than a second. When I
copied the SQL statement from Report Builder to use with ODBC, it took
approximately 15 seconds to retrieve the data.
Am I missing something? Is there a better way to pull data for web pages?
Any help would be greatly appreciated.
Chris
Christopher Gitzlaff, MSCIS
Manager - Information Systems & Technology
Major Industries, Inc.
Phone: 715.842.4616 ext. 323
Email: cgitzlaff@...
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129dvqev4/M=298184.6191685.7192823.3001176/D=gr
oups/S=1705007183:HM/EXP=1111097525/A=2593423/R=0/SIG=11el9gslf/*http:/www.n
etflix.com/Default?mqso=60190075> click here
<http://us.adserver.yahoo.com/l?M=298184.6191685.7192823.3001176/D=groups/S=
:HM/A=2593423/rand=517590561>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Tracking #: 7E9F867FA475DF43B287C6B7D3DFFDE216E3B2D9
Yahoo! Groups Links
Chris
Welcome to life with ODBC and Progress. You may want to try to change some
of the links or selection criteria.
Jeremy
What language are you using for web based reporting?
We use Coldfusion here and I was having some horrible ODBC issues as
well. I just finished switching to using the native JDBC driver rather
than the ODBC and it works 10 times better. If you're using ASP or
something similar that relies on Windows creating the datasource for you
then you might be stuck using ODBC which does seem to have some issues.
On a similar note, with the latest release of Coldfusion MX 7 they have
released a report builder that is absolutely incredible. I'm not the
Vantage person here but I have created some web apps that tie into
Vantage so I have used it a bit here and there. But when I showed the
new report builder in Coldfusion to our Vantage guy he fell in love with
it and has started moving everything away from the Vantage report
builder and will most likely be getting rid of Crystal Reports. I know
most companies can't justify spending the money to buy CFMX 7 but if
anyone on this list is currently using Coldfusion, definitely look into
upgrading to use their reporting tool. It's years ahead of Vantage's.
Ben
and
a
This
I
pages?
Chris
ADVERTISEMENT
click here
D=groups/S=1705007183:HM/EXP=1111097525/A=2593423/R=0/SIG=11el9gslf/*htt
p:/www.netflix.com/Default?mqso=60190075>
s/S=:HM/A=2593423/rand=517590561>
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Christopher,
Shirley Graver
Rubber Associates
_____
Chris
ADVERTISEMENT
_____
Yahoo! Groups Links
Hi Shirley. I had replied to a message yesterday, but just realized it
didn't go back to the group. I'll include that in my response.
We have two separate groups configured on the Progress / Vantage database (a
4GL group and an ODBC group). We're on version 6.0 so the port for ODBC on
the Progress / Vantage server is 6050.
I installed Progress on our internal Intranet server (web server). We are
using Microsoft IIS and Active Server Pages (ASP). A standard client
install on the web server should work fine - the Merant ODBC drivers for
Progress will be installed. Then you go to "Control Panel -> Administrative
Tools -> Data Sources (ODBC)" and add a system DSN pointing to the Progress
server. Epicor has documentation on how to do this.
We connect to the database using ADODB - simple example:
Code Snippet
Dim arrOrder
rstOrder.Open strSQL, dbsVantage arrOrder = rstOrder.GetRows rstOrder.Close
dbsVantage.Close
Response.Write "<head><title>Sample</title></head>" & vbCrLf Response.Write
"<body>" & vbCrLf
Dim i
Next
End Code Snippet
We have found that dumping the recordset to an array produces much better
results than working with the recordset directly. Instead of all the
traffic back and forth between servers, the array is stored in memory - much
faster.
Still, this is slower than the native Progress tools like Report Builder.
Chris
Christopher,
Associates
_____
Chris
ADVERTISEMENT
_____
Yahoo! Groups Links
Yahoo! Groups Links
