ODBC problem after replacing server
There's also a file on this group explaining how to configure ODBC post d&L.
I think there's an ODBC folder.
cubcrafters_it
Sent: Wednesday, July 31, 2013 12:06 PM
Subject: [Vantage] Re: ODBC problem after replacing server
If you did a dump and load, you may need to reconfigure ODBC. Support has a
kit/document with info I believe.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "stu"
<bobbieandstu@...> wrote:
> After restoring the server, we cannot access vista 8.0 database using
ODBC.
> Everything else seems to work. The only issue is custom reports. I get an
> "authorization" failure error. When I try to refresh the ODBC connection,
I
> get a 193 error. Any suggestions?
> Stu Horwitz
After restoring the server, we cannot access vista 8.0 database using ODBC.
"authorization" failure error. When I try to refresh the ODBC connection, I
Stu Horwitz
If you did a dump and load, you may need to reconfigure ODBC. Support has a kit/document with info I believe.
> Stu Horwitz
