ODBC Setup Error (System DSN) [6.1.533]
Thank you,
That fixed it.
Chris
Of Stephen Edginton
Sent: Friday, June 15, 2007 12:02 PM
Subject: RE: [Vantage] ODBC Setup Error (System DSN) [6.1.533]
Chris,
The issue is a registry entry in the ODBCINST.INI section
HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI
Find the Merant 3.6 key
Then ensure the path to setup is correct.
The Dll should end in an s.dll
Regards,
Stephen
Behalf
Of Chris Crosta
Sent: 15 June 2007 18:03
Subject: [Vantage] ODBC Setup Error (System DSN) [6.1.533]
I am receiving the following errors while trying to add the Merant data
source as a System DSN.
The setup routines for the Merant 3.60 32-BIT Progress SQL92 v9.1D ODBC
driver could not be accessed. Please reinstall the driver.
And
The setup routines for the ODBC driver could not be accessed. Please
Do I need to reinstall Vantage on the computer or is there another way
to just update the driver? Vantage runs fine it's is just the ODBC
connection.
Chris
And
connection.
Chris
This sounds like a permissions issue. You may reinstall the driver,
however, make sure the user has administrative access to the PC in order
update the necessary registry entries. If they have the necessary
permissions and you still can not get it to work, you will manually have
to uninstall the Progress driver which involves diving through the
registry and cleaning out the necessary entries there - I'd rather have
dental work done :-).
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
317.578.2393
jason@...
Of Chris Crosta
Sent: Friday, June 15, 2007 1:03 PM
And
connection.
Chris
It shouldn't be a permissions issue as I have full administrative rights
to the computer. I think at this point I will just reformat and
reinstall.
Chris
Of Jason Claggett
Sent: Friday, June 15, 2007 10:45 AM
Jason Claggett
MCP #3856159
317.578.2393
jason@... <mailto:jason%402wtech.com>
Behalf
Of Chris Crosta
And
connection.
Chris
> reinstall.
Did your drive mappings change or did the name of the server change where you
ran the original setup?
Mark W.
No changes on either have occurred since the original setup.
Chris
Of Mark Wonsil
Sent: Friday, June 15, 2007 11:34 AM
rights
> reinstall.
where you
Mark W.
Chris,
Regards,
Stephen
Of Chris Crosta
And
connection.
Chris
