ODBC setup on Windows 7
Maybe I am confused by your statement, but I am talking about forms we
modified and having a problem viewing on this workstation.
I get a Crystal runtime error.
Manasa
630.806.2000 x1515
Of bw2868bond
Sent: Thursday, July 07, 2011 5:10 PM
Subject: [Vantage] Re: ODBC setup on Windows 7
None of the standard 'reports' in V8 and V8.03 require ODBC
Back on 8.00 I had to use ODBC to link PO print to UD table. Once we
moved to 8.03, I was able to include the UD data in the XML to Crystal
and the need for ODBC went away for us.
"Manasa Reddy" <manasa@...> wrote:
> Well let me ask this...I have to set up ODBC for my people to 'view' a
> PO, SO, etc.
> How are you guys who are using version 8 and 8.03 able to have people
> view these forms if installing ODBC doesn't work on Windows 7?
> I must be missing something...
> Manasa
> 630.806.2000 x1515
Behalf
> Of Chris Henzel
> Sent: Thursday, July 07, 2011 2:43 PM
> Subject: RE: [Vantage] ODBC setup on Windows 7
> I've only managed to get the 32bit driver to work correctly on Windows
> 7.
> The 64bit version installs 'correctly' but just gives an 'odbc call
> failed' error when used. Not had any time to really look into it.
> Behalf
> Of Manasa Reddy
> Sent: 07 July 2011 15:26
> Subject: [Vantage] ODBC setup on Windows 7
> Ok I must be brain dead because I am not able to get this set up on my
> windows 7 workstation.
> Anyone have any tips or tricks?
> Thanks!
> M. Manasa Reddy
> Welding Company of America
> manasa@... <mailto:manasa%40weldcoa.com>
> <mailto:manasa@... <mailto:manasa%40weldcoa.com>
> <mailto:manasa%40weldcoa.com> >
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> constant innovation
> www.weldcoa.com <http://www.weldcoa.com/>
> Chris Henzel
> Epicor 9 Project Manager
> Tel: +44 (0)1582 436150
> Mob: 07836 314164
> This message contains confidential information and is intended only
for
> the intended recipients. If you are not an intended recipient you
should
> not disseminate, distribute or copy this email. Please notify the
sender
> if you have received this email by mistake and delete it from your
> system.Email transmission cannot be guaranteed to be secure or
> error-free as information could be intercepted, corrupted, lost,
> destroyed, arrive late or incomplete, or contain viruses. The sender
> does not accept liability for any errors or omissions in the contents
of
> this message, which arise as a result of email transmission.
Registered
> Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England.
Tel:
> +44 (0)1582 731144. Company No. 3450138.
Thanks!
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
constant innovation
7.
Of Manasa Reddy
Thanks!
M. Manasa Reddy
<mailto:manasa@... <mailto:manasa%40weldcoa.com> >
800.852.2325
630.806.2000 ofc
630.806.2001 fax
constant innovation
Chris HenzelEpicor 9 Project ManagerTel: +44 (0)1582 436150Mob: 07836 314164
This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this email. Please notify the sender if you have received this email by mistake and delete it from your system.Email transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender does not accept liability for any errors or omissions in the contents of this message, which arise as a result of email transmission. Registered Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton, LU1 3LD, England. Tel: +44 (0)1582 731144. Company No. 3450138.
PO, SO, etc.
Manasa
630.806.2000 x1515
Of Chris Henzel
7.
Behalf
Of Manasa Reddy
Thanks!
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
constant innovation
Chris Henzel
Mob: 07836 314164
Back on 8.00 I had to use ODBC to link PO print to UD table. Once we moved to 8.03, I was able to include the UD data in the XML to Crystal and the need for ODBC went away for us.
> PO, SO, etc.
> Manasa
> 630.806.2000 x1515
> Of Chris Henzel
> 7.
> Behalf
> Of Manasa Reddy
> Thanks!
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> constant innovation
> Chris Henzel
> Mob: 07836 314164
Is windows 7 32 bit or 64 bit?
Steve
Manasa Reddy
Sent: Thursday, July 07, 2011 4:09 PM
PO, SO, etc.
Manasa
630.806.2000 x1515
Behalf
Of Chris Henzel
7.
Behalf
Of Manasa Reddy
Thanks!
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
constant innovation
Chris Henzel
Mob: 07836 314164
Manasa,
Not exactly sure where you are stuck, however I just setup my first ODBC/Windows 7 machine and everything is working as expected.
This is assuming you are working on the x64 side.
1. Create your txt/reg file as described in the instructions, but make sure to follow the x64 detail.
2. Update the registry by launching the file from #1.
3. <Here is the change>... Instead of going through 'Administrative Tools' to launch the ODBC menu you will go to "C:\Windows\SysWOW64 and launch the "odbcad32" executable. This will launch ODBC where you can see the OpenEdge drivers (those listed under the registry key "Wow6432Node") under System DSN.
4. Setup your System DSN.
My issue was in launching ODBC through 'Administrative Tools'. I could not see any of the drivers in installed in the System DSN. Launching the "odbcad32" executable gave me those options and everything went as usual.
Hope that is what you were looking fo.
Jeff
> Thanks!
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> constant innovation
64 bit
Manasa
630.806.2000 x1515
Of Steve_E
Sent: Thursday, July 07, 2011 4:18 PM
Steve
Behalf Of
Manasa Reddy
PO, SO, etc.
Manasa
630.806.2000 x1515
Behalf
Of Chris Henzel
7.
Behalf
Of Manasa Reddy
Thanks!
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
constant innovation
Chris Henzel
Mob: 07836 314164
