Brian,
I called vantage support to see if they had any instructions and they
said the instructions we're the same as version 3.5, which I have a
copy of. I wouldn't mind seeing what you've got and make sure
they're the same. Send to bstenglein@....
Brian
Brian
--- In vantage@egroups.com, Brian Davis <bdavis@w...> wrote:
> Brian,
> When I received mine, I also received an email from Epicor with
detailed
> instructions. Believe it or not, following the steps outlined in
the
> instructions actually resulted in a successful installation on the
first
> try. It did not solve the problem, so I can't really recommend for
> installing it. But it also didn't create any new problems, so I
can't
> really recommend against installing it either.
> If you want the instructions, I would be happy to forward them to
you. Let
> me know...B
> -----Original Message-----
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Monday, August 21, 2000 9:30 AM
> To: vantage@egroups.com
> Subject: [Vantage] ODBC Version 3.6
> I've just received my copy of Data Direct 3.6, but from the sounds
of
> it, it doesn't solve the problems we're all having with Access.
Does
> anyone have any positive or negative things to say about installing
> it? Is it much different than installing 3.5? Is it worth the
time
> to upgrade?
> We no longer allow attachments to files. To access/share Report
Files,
> please go to the following link:
http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try
it, go to
> www.egroups.com, login and be sure to save your password, choose My
Groups,
> choose Vantage, then choose Files. If you save the password, the
link above
> will work the next time you try it.)
