Odd Problem - Order Line/Rel Need By Date
Interesting... I am on 9.05.607a
reply Signature
Joshua Giese
CTO
920.437.6400 Ext. 337
Site ID: 27450-E905607A-SQL64
----- Original Message -----
Sent: Tuesday, May 22, 2012 12:57:22 PM
Subject: RE: [Vantage] Odd Problem - Order Line/Rel Need By Date
8.803.409C
I put in a ticket with Epicor this morning regarding this. Hopefully they know what is happening.
Scott
From: vantage@yahoogroups.com [mailto: vantage@yahoogroups.com ] On Behalf Of Joshua Giese
Sent: Tuesday, May 22, 2012 12:43 PM
Subject: Re: [Vantage] Odd Problem - Order Line/Rel Need By Date
No idea at all. What version are you on? Anyone know if this is a bug fixed in 70 0?
reply Signature
Joshua Giese
CTO
From: "Scott Litzau" < scott.litzau@... <mailto:scott.litzau%40olympusgrp.com> >
Sent: Monday, May 21, 2012 4:00:53 PM
Yes, that is exactly the same problem.
Any ideas?
Scott
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of
Joshua Giese
Sent: Friday, May 18, 2012 8:13 AM
If you try to delete the need by date that shows up it doesn't go away
right? It just fills back in? I have that issue..
Joshua Giese
CTO
_____
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of litzer1
Sent: Thursday, May 17, 2012 4:50 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Odd Problem - Order Line/Rel Need By Date
I have an odd problem where when entering a Sales Order Line with certain
part numbers the Line and Release Need By Date field is being populated
with the Order Date after saving the record and when the Need By Date is
blank at the Header level. If there is a value in the Need By Date at the
Header it picks up that date but if it is blank at the Header the Order
Date is being populated. This is only happening to certain part numbers. I
have check customizations and BPMs and have found nothing that would be
causing this.
Any help appreciated.
Scott
I have an odd problem where when entering a Sales Order Line with certain part numbers the Line and Release Need By Date field is being populated with the Order Date after saving the record and when the Need By Date is blank at the Header level. If there is a value in the Need By Date at the Header it picks up that date but if it is blank at the Header the Order Date is being populated. This is only happening to certain part numbers. I have check customizations and BPMs and have found nothing that would be causing this.
Scott
Joshua Giese
CTO
_____
Of litzer1
causing this.
Scott
Any ideas?
Scott
Joshua Giese
Joshua Giese
CTO
_____
Behalf
Of litzer1
causing this.
Scott
reply Signature
Joshua Giese
CTO
Any ideas?
Scott
Joshua Giese
Joshua Giese
CTO
_____
Behalf
Of litzer1
causing this.
Scott
8.803.409C
Scott
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
reply Signature
Joshua Giese
CTO
From: "Scott Litzau" <scott.litzau@... <mailto:scott.litzau%40olympusgrp.com> >
Any ideas?
Scott
Joshua Giese
Joshua Giese
CTO
_____
Behalf
Of litzer1
causing this.
Scott
