Odd Selection List behavor in 2025.2.11
I am trying to build a selection list for all Product Families within a Quote, but I am running into some odd behavior.
I have a dataview discProdFam that is being populated after GetByID, and a Transview variable setup to store the selections in the list. But my list won’t populate unless it is bound to the Transview variable, in Dual mode, and you select ALL, which will then show the options as selected.
Let me know what you think! Thanks!
Selection List setup with no EpBinding.
Confirmed Dataview is populated by BAQ, but Selection List not loaded.
Selections show up after EpBinding to TransView.discProdFamSelection is added and mode changed to Dual, and user has to click All. (not ideal)
Error in Console log complaining about column setup, but everything looks correct.
Scratch that. Since I was using the TransView I needed to initialize a row before populating the list. I did that in the GetByID with a rowupdate, which will also be used to reset the values.
it is working now.
