Hi Grzegorz
I'm using a system BAM which triggers on the change of the field part.partnum. This probably uses the part.update method, I really don't know. How would I create a customization in 6.1 to do this?
Mark D
Mark D
--- In vantage@yahoogroups.com, "Grzegorz (phoenix_)" <phoenix_@...> wrote:
> I am assuming that your BAM is working on Part.Update method. If so, why
> you are not create a simple customization (instead of BAM) that will not
> allow to save a Part Record unless a your field will be filled out?
> Grzegorz Szczepañski
> Dnia 11-11-2009 o godz. 22:07 dupuismd napisa³(a):
> > Elementy potencjalnie niebezpieczne zosta³y zablokowane.
> > Hi group
> > Anyone out there know how to open the Vantage part maintenance screen
> and populate it with a given part number using 4gl? I have a bam to run
> a .p which triggers if a field is blank. A message says "you left this
> field blank". I would like to keep the screen open but I figure I could
> perhaps reopen it if I capture the part number.
> > TIA
> > Mark D
> Bia³e szaleñstwo nadci±ga!
> Dok±d w tym roku? Narty.wp.pl
> Sprawd¼: http://klik.wp.pl/?adr=http%3A%2F%2Fcorto.www.wp.pl%2Fas%2Fnarty2009-10.html&sid=911
