# Off-subject
**Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9)
**Created:** 2005-02-10 14:56 UTC
**Views:** 460
**Replies:** 3
**URL:** https://www.epiusers.help/t/off-subject/370
## Post #1 by @system
Definitely, you can install other devices into a Gateway. Gateway and
other manufacturers have some proprietary components, such as memory
and motherboard architecture, but devises like drives, printers,
scanners, etc. should work fine!
Alan
--- In vantage@yahoogroups.com, "Wendy Pursche" <wpursche@s...> wrote:
> Thanks for all of your responses about the HP printers. I have
another question off of the topic. I know some of the companies out
there have Gateway workstations. I have heard that Gateway is only
compatible with Gateway. Is this true? I am looking to install a
R/W CDROM on a workstation. Do I have to buy it from Gateway or can
I buy it from another vendor?
> Thanks again!
> Wendy Pursche
> Network Administrator
> Schmald Tool & Die, Inc.
> (810) 743-1600 ext.323
> wpursche@s...
## Post #2 by @system
Thanks for all of your responses about the HP printers. I have another question off of the topic. I know some of the companies out there have Gateway workstations. I have heard that Gateway is only compatible with Gateway. Is this true? I am looking to install a R/W CDROM on a workstation. Do I have to buy it from Gateway or can I buy it from another vendor?
Thanks again!
Wendy Pursche
wpursche@...
## Post #3 by @system
I do some PC & network work "on the side", and one client had a decent
number of Gateways. In the ones I saw there, everything was industry
standard. Only hitch is some of them have sound or video integrated onto
the system board; but that's true of most of the big manufacturers. Any
old CD-Rom will most likely work for you, and probably be about 1/3 what
Gateway would charge.
Also, writable CD drives are terribly unreliable. Plextor and Sony are
some of the better bets.
-Wayne Cox
## Post #4 by @system
Wendy,
As stated by others, You can most likely put any kind of non-Gateway device
into your Gateway PC, however you might be voiding any warrantee you have on
the system. Just a warning. I have had problems with them on this point
before.
John Yohannan
vendor?
Thanks again!
Wendy Pursche
wpursche@...
0% Introductory APR!
Instant Approval!
Aria Visa - get yours today.
http://click.egroups.com/1/6035/13/_/411782/_/963256244/
please go to the following link:
http://www.egroups.com/files/vantage/
**Canonical:** https://www.epiusers.help/t/off-subject/370
**Original content:** https://www.epiusers.help/t/off-subject/370
